2nd gen rear shock replacement help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by silverback, Aug 3, 2010.
  1. Aug 3, 2010 at 5:57 PM
    silverback
    silverback [OP] Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    I searched for the DIY on this but couldn't find anything. My question is do we have to compress the shock to get it out and in? Or does the new shock just plop right in like a loose whore? We have the truck jacked at the rear axel housing with both tires off. The new shock appears to be fully extended and much longer than the oem shock. Thanks
  2. Aug 3, 2010 at 6:01 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    You jack up the rear, place jack stands under the frame at the rear, then lower the jack til there is no compression. But keep it there. Then it should fit.
  3. Aug 3, 2010 at 6:02 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    What kind of shocks are they?
  4. Aug 3, 2010 at 7:29 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    No need to jack the rear or take the tires off. Simply loosen the hardware on the old shocks and remove. Mount the top of the new shock first (obviously) and then compress it into place (by hand) and install the bottom hardware. It can be done in less than 20 mins just lying in your driveway.
    Easy as pie...
  5. Aug 3, 2010 at 7:44 PM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    X2
    I just did mine (5100's) a few eeks ago.
    GA
  6. Aug 3, 2010 at 8:13 PM
    Riff Raff
    Riff Raff Active Member
    Riff
    Iowa
    05 DC 4x4 TRD SR5 V6 AUTO
    Yup... shouldn't have to jack anything... just remove old shock.. compress new one to fit...
  7. Aug 4, 2010 at 5:24 PM
    silverback
    central CA
    2006 Prerunner SR5
    yea for some reason the first couple times of trying to compress the shock by hand I couldnt do it. after setting the shock upright on the pavement I got it to compress and from there I could do it by hand. I did take the tires off and jack the damn thing up though, already had that part done before the posts. Anyways thanks for your input guys always helpful.
  8. Aug 29, 2010 at 5:27 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    is there a trick to tightening the nut on the upper shock mount without the shaft spinning?
  9. Aug 29, 2010 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What kinda shocks are you installing?
  10. Aug 29, 2010 at 5:55 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ 5100s for a friend
  11. Aug 29, 2010 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRC, It uses a 5mm hex wrench in the top of the shaft:
    Insert the wrench, and use an open wrench to tighten it:
  12. Aug 29, 2010 at 6:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, Some shocks have the very top of the shaft fit for a small wrench to hold it from turning:
  13. Aug 29, 2010 at 6:04 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    You rock Chris. That was the very same thing that got me too when I contacted you (I still feel bad about my timing). Always there!
    Good luck Jason.
  14. Aug 29, 2010 at 6:07 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    amazing! thanks! i never would have noticed that hex on top without you telling me
  15. Aug 29, 2010 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking of making a new post and sticking it....:)
