2nd gen rearend in 1st gen!! will it work?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tunajoe13, Dec 1, 2013.
  1. Dec 2, 2013 at 3:12 AM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    DTF am I are swapping from a stock 99 Elocker 4.10 Axle rear end to a fully backhalved / linked second gen rear end with Elocker and 4.56s to match my 5" over kit up front and push my 35s.
    And to push it that much further, just recently supercharged
  2. Dec 2, 2013 at 6:51 AM
    BamaToy1997
    Bill
    Navarre, FL
    This is taken directly from the 4x4wire.com website on Tacoma axle information. Note the very last line in bold:
    As I said, Me and a buddy have already tried to use a 2nd gen 3rd member, and it would not even fit inside the opening of the 1st gen differential. That and the bolt patterns did not match.
  3. Dec 2, 2013 at 7:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bill...its says right there in the first line..
    But it i says 4runners don't...
    no one in this thread is using a 4runner..
  4. Dec 2, 2013 at 8:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    It is not just 4 Runner specific. If you read the entire section, including my specific quoted text it shows that it is 2000-2007 as I recall. The truck in question is a 1999 as I recall from the OP. He can try it if he wants, but I am telling you from personal experience, the 3rd members will not swap out between those two trucks. It does specifically state "This diff cannot be fitted to an older style 8" axle because it uses a larger diameter mounting bolt pattern and because more space inside the housing necessary to accommodate the large bearing cap." And like I said, we tried to get a 3rd member from a 2nd gen to fit a 1997, which has the same rear end as the 1999, and it won't fit. Ignoring the sentence that mentions 4Runner, the LAST SENTENCE in bold states you cannot use the 2000-2007 Toyota diff on an older 8" rear diff.
  5. Dec 2, 2013 at 8:29 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    the V6 diff though is supposed to be for pre tacomas..
    I mean i have an 8.4'' diff. My door panel IDs it..not the pre tacoma V6/Turbo one. and im a 96...
  6. Dec 2, 2013 at 10:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    Here is the direct link to the entire thread. If you scroll down to the half way point or so, it is the section on rear differentials, and it shows what I was talking about. Now perhaps I am not understanding 100% what I am reading. Lord knows I am human just like everyone else. What I was looking for was supporting information to confirm what I already know to be true, in that a 2nd gen rear 3rd member will not fit in a 1999. As I mentioned, this was already tried, and the 2rd member did not even come reasonably close to fitting inside the housing. Perhaps my interpretation of the information on the site is incorrect, but the actual fitment I do know I am correct on. You all read the page and let me know what it sounds like to you. I am always open for correction in my information so that I can provide the right information to others later.
    LINK: http://home.4x4wire.com/erik/diffs/
  7. Dec 2, 2013 at 11:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    I guess I can see how you could read it that way. To me I interpreted it as saying "older 8" diff" would be anything prior to that specific diff that was in that section. Hmmm. Food for thought. Either way, still won't fit.:D
  8. Dec 2, 2013 at 11:37 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    you sure the diff you tried wasn't a e locker to and open diff housing? cause that will never work without major housing mods..
  9. Dec 2, 2013 at 12:35 PM
    toastyjosh
    toastyjosh Well-Known Member
    northern New mexico
    95 dark green taco(sold), 2005 chevy 2500HD duramax
    Ok I think this all just confused me even more.
    So A 2nd gen elocker rear diff will or will not work in a 1st gen 8.4?
  10. Dec 2, 2013 at 12:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no elocker will ever fit in any 8.4'' housing period.
  11. Dec 2, 2013 at 12:49 PM
    toastyjosh
    northern New mexico
    Thanks!!
    So what about swaping the whole axel. I know its 5 in wider, 2.5 on each side. The spring pearches are different, thesere has to be a kit some where to swap this?
  12. Dec 2, 2013 at 4:30 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    They have the same t100 "8.4" axle. Just different lengths :)
  13. Dec 2, 2013 at 6:53 PM
    BamaToy1997
    Bill
    Navarre, FL
    Uh, yeah, I know the difference between them. It was an open diff 3rd from a 2nd gen and an open diff 3rd from a 1997. It would not fit. At all.
  14. Dec 2, 2013 at 7:43 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Maybe yall were drunk.:stirthepot:
  15. Dec 2, 2013 at 9:59 PM
    #35
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Popcorns
  16. Dec 2, 2013 at 10:08 PM
    #36
    Tunajoe13
    Tunajoe13 [OP] Well-Known Member
    Joe
    Parrish, FL
    05’ Base V6 4x4 extended cab
    20'' wheels, 34''x11" Toyo Open Country A/T II tires, 4.88 Gears, ARB Locking Rear Diff, ARB compressor, Fiberglass bed cover, Weathertech floor liners, Weathertech side window protectors, Allpro Apex front bumper, Allpro Apex rear bumper Allpro 3'' Expo rear leaf kit, Allpro hidden hitch receiver, 10'' aluminum drop hitch, Camburg 4'' spindles, Allpro uniball uca's, Ottonavi 6.5'' touch screen G.P.S, 09' Tailgate with factory reverse camera, Stampede hood protector, Raptor style grill and hood mesh (Homertaco), Piaa 5100 Fog lights, Volt HID's, Viper5704 Alarm with remote start, Limo tint, Scangauge II, TRD cai, URD 3'' Mk2 exhaust, Doug Thorley LT headers, URD Y-pipe, Unichip PnP Pcm, Unichip Flux2 display, Factory Sport hood....
    yeah, lol. It worked!! thanks all!!
    only issue is was the plate that connects the 3rd member to the drive shaft was larger on the 2nd gen so he has to use the one from his old 3rd.
  17. Dec 3, 2013 at 12:05 PM
    #37
    TrdSurgie
    TrdSurgie revised
    Oahu
    VICTORY !!!!!!!!!!:p
  18. Dec 4, 2013 at 8:31 AM
    #38
    BamaToy1997
    Bill
    Navarre, FL
    Interesting. I guess I stand corrected on that particular truck swap. And no, not drunk. We were totally sober and I spent an hour trying to get the 3rd member to fit inside the housing. It was hitting on multiple locations and wouldn't fit the opening, so I just said the heck with it. What I was doing was trying to get a 3rd out of a 2007 Tacoma with an aftermarket mechanical locker to fit into my 97. It was a no-go. Glad to see that it did work out. I will be doing some more research.
  19. Dec 4, 2013 at 8:57 AM
    #39
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Even though he now has absolutely no bottom end anymore I would be interested to know what kind of mpg he got on his trip.
  20. Dec 4, 2013 at 3:09 PM
    #40
    TrdSurgie
    TrdSurgie revised
    Oahu
    Its okay Bill, you can't know everything.
