2nd gen, recommendation needed!
Discussion in 'Audio & Video' started by Bigcanoe, Jan 22, 2013.
  1. Jan 22, 2013 at 4:49 AM
    Bigcanoe
    Bigcanoe [OP] Active Member
    Moncure , NC
    06 double cab 4x4 sr5
    Hi all,
    I want to replace the stock radio in my 2006. I want something whose colors will match the dash at night, so I guess orange? I dont need a ton of fancy features, but I need at least aux input (the whole reason for doing this), single CD, FM radio. I plan to order from Crutchfield to get the install bits, and I want to spend $100 or less.
    If I could spend $50 or less on a "box" to add a quality aux port to the stock radio, I would probably go that route and keep the stock look.
    Suggestions?
  2. Jan 22, 2013 at 9:44 AM
    pinktaco808
    pinktaco808 Hot Steppa
    anything
  3. Jan 22, 2013 at 9:50 AM
    Bigcanoe
    Moncure , NC
    I guess there are too many options to recommend, Crutchfield is full of them!
  4. Jan 22, 2013 at 9:54 AM
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    I think the expense limit of 100 may be a problem. Many different double din decks. On my Pioneer, I have a choice of about 5 colors to choose from (orange being one of them).
  5. Jan 22, 2013 at 9:55 AM
    Bigcanoe
    Moncure , NC
    Very nice. I am considering upping my budget a bit. I think the double din would look sweet in the Taco. I dont want anything with a flip face or removeable face. I do need aux and maybe ipod/iphone, and bluetooth would be nice.
    I dont want anything to glity with a ton of lights and shiny buttons or crazy design :)
  6. Jan 22, 2013 at 10:03 AM
    AllMountainToy
    Northern California
    what you are describing is the factory radio. Why are you replacing? More power?
  7. Jan 22, 2013 at 10:05 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    If you are replacing to get axillary, there is a mod you can do to get an auxiliary input with the stock head unit. I did it in my 05.
  8. Jan 22, 2013 at 10:05 AM
    Bigcanoe
    Moncure , NC
    Aux port...blue tooth and maybe ipod?
  9. Jan 22, 2013 at 10:06 AM
    spitfire501
    spitfire501 Well-Known Member
    Austin
    Napa, CA
    i know that my 09 at least had a factory aux input. i'm not sure what year they atarted doing that though. i had the stock setup not jbl
  10. Jan 22, 2013 at 10:06 AM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
  11. Jan 22, 2013 at 10:08 AM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
  12. Jan 22, 2013 at 10:14 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    How about <$10. If you are only looking to add the Aux. I can help you out if you want to do it, I live in Cary.
  13. Jan 22, 2013 at 10:18 AM
    Bigcanoe
    Moncure , NC
    I might also consider an after market plug in thingy like the ones from USA or Grom Audio?
  14. Jan 22, 2013 at 10:19 AM
    Bigcanoe
    Moncure , NC
    Tempting, but I worry about frying something, I am a newbie solderer...is it a touchy spot to get to and solder? I have soldered wire to wire, but not wire to board.
  15. Jan 22, 2013 at 10:21 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    It's not bad to do. If you're looking at maybe going aftermarket anyways who cares if you fry it. Like I said I can give you a hand I'm close.
  16. Jan 22, 2013 at 8:55 PM
    Speedway4BY
    Speedway4BY Member
    Armando
    Flagstaff, AZ
    '08 Double Cab Sport
  17. Jan 23, 2013 at 5:30 AM
    Bigcanoe
    Moncure , NC
    Thanks for the offer! I am about to pull the trigger on an aftermarket, I think I will enjoy all the new features. If I bail I will get in touch for some soldering help :)
  18. Jan 23, 2013 at 7:20 AM
    Speedway4BY
    Speedway4BY Member
    Armando
    Flagstaff, AZ
    OP I am also in the market for a head unit. I have been debating on the inexpensive single DIN or spending a little more for a touchscreen. There is no doubt about it the touchscreens look awesome in the Tacoma. From what I have researched the above mentioned unit is a great no nonsense unit but I am being swayed to a touchscreen after looking through some the other builds on this sight. I found the Pioneer AVH-P2400BT which is a last year's model discounted on Crutchfield. In my opinion it is a clean unit and I like it because it comes with the extras like bluetooth. The downside is it has a smaller screen and I don't prefer the aux and usb ports on the front but you cant beat the price. Look for the $25 dollar discount code online and it comes to $275 shipped.
    The other alternative is to look on Amazon but of course it doesn't come with the install kit. Good Luck and let us know what you get.
