2nd gen recovery loop.
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by mustangwilly, Feb 9, 2011.
  1. Apr 30, 2012 at 8:05 PM
    #81
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
  2. Apr 30, 2012 at 9:50 PM
    #82
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
  3. May 1, 2012 at 3:55 AM
    #83
    oneshot808
    oneshot808 Well-Known Member
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    Wet Okoles/Weather tech all around, LED's +HIDS, 6"Fabtech w/ Fox front & rear
    ]1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.oneshot808
  4. May 1, 2012 at 11:10 AM
    #84
    Rez
    Rez Well-Known Member
    Vancouver BC
    TRD Sport
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.oneshot808
    7.Rez
  5. May 1, 2012 at 11:31 AM
    #85
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    put me in, Ill be your test fitter to see if these work with an ARB
  6. May 1, 2012 at 12:01 PM
    #86
    mustangwilly
    mustangwilly [OP] Well-Known Member
    2017 DCSB OR Quicksand MT
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.oneshot808
    7.Rez
    8.SNWTACO
  7. May 1, 2012 at 8:22 PM
    #87
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.oneshot808
    7.Rez
    8.SNWTACO
    9. Allanox77
    10.
    ^^^^^^^^Quit looking and put your name here
  8. May 2, 2012 at 5:08 AM
    #88
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    i will say, i bought one from the first batch, and it worked great! i ended up selling it to a local guy bc i got a steel bumpa...
  9. May 3, 2012 at 5:34 AM
    #89
    Techoma
    Alta Mesa, AZ
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.oneshot808
    7.Rez
    8.SNWTACO
    9. Allanox77
    10.
    ^^^^^^^^Quit looking and put your name here! Come on... lets do this! TTT!!!!!
  10. May 3, 2012 at 12:49 PM
    #90
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Anyone ever determine if this is compatible with the OEM Skid Plate?
    Uh..........Without Hacking It!
    CC
  11. May 6, 2012 at 3:37 AM
    #91
    oneshot808
    Oahu, Hawaii
    16 T4R 4x4 GH05T
    sorry guys. wifey doesnt want me spending 40$ lol. im out
  12. May 7, 2012 at 11:32 AM
    #92
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Sub'd - going to check if this will work for me
  13. May 7, 2012 at 12:06 PM
    #93
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.oneshot808
    7.Rez
    8.SNWTACO
    9. Allanox77
    10. hamnswiss on rye
    :yay:
  14. May 7, 2012 at 12:32 PM
    #94
    sandjunkie
    Aaron
    OC
    oneshot808 dropped out
    This is the list so far:
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.Rez
    7.SNWTACO
    8. Allanox77
    9. hamnswiss on rye
  15. May 7, 2012 at 1:59 PM
    #95
    Techoma
    Alta Mesa, AZ
    Oh so close again!!!!
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.Rez
    7.SNWTACO
    8. Allanox77
    9. hamnswiss on rye
    10.
    ^^^^^^^Put yer name dare^^^^^^^
  16. May 7, 2012 at 2:11 PM
    #96
    Cape Codder
    Jack
    I'd be interested.................but
    CC
  17. May 7, 2012 at 2:16 PM
    #97
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I had mine on with the black OEM skid, I just had to bend the very tippy edge of it. No biggie, couldn't even tell.
  18. May 9, 2012 at 8:35 AM
    #98
    Rez
    Vancouver BC
    TRD Sport
    Sorry guys, I am ordering a bumper with shakel loops, don't need this anymore. I am out
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.SNWTACO
    7. Allanox77
    8. hamnswiss on rye
  19. May 9, 2012 at 11:16 AM
    #99
    PL 4x4
    PL 4x4 Well-Known Member
    PL
    Jacksonville, FL
    SOLD: 2011 4WD MGM DCLB
    Eibach Coils, Bilsteins at .85, 1/4" Toytec Spacers both sides, 2" AAL and Bilsteins on rear. Completely debadged, yellow wire mod, rear diff breather relocate.
    I'm in.
    1.2005Techoma
    2.DANTEISME
    3.Tubesock
    4.Nick54
    5. F75Gunslinger
    6.SNWTACO
    7. Allanox77
    8. hamnswiss on rye
    9. PL 4x4
  20. May 9, 2012 at 4:11 PM
    #100
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    bump, lets get 1 more!
