2nd Gen Regular v Mid-Grade v Premium Fuel Experiment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ziggynagy, May 19, 2015.
  1. May 7, 2016 at 10:06 AM
    #41
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Looks to me that your best overall mileage was with 89 octane. That's what I use, and I've averaged 20 mpg overall since I bought the truck.
  2. May 7, 2016 at 10:22 AM
    #42
    ziggynagy
    ziggynagy [OP] All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    because we're all secretly planning to get a prius as our second vehicle and want to justify the cost.
    Yea, I typically run 89 as well.
  3. May 7, 2016 at 10:43 AM
    #43
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I have run mid-grade since new also. Around here, though, octane is 86/88/90. Some altitude thing:
    Short answer: You can get by with lower octane numbers at higher elevations.
    Longer answer: In a gasoline engine the fuel/air mixture is compressed before being ignited by the spark plug. When you compress a gas it heats up. If this mixture heats up too much it will ignite before it's supposed to, something commonly referred to as knocking. The octane number is a measure of how well gasoline can resist knocking. At higher elevations the air is thinner, so it heats up less when you compress it. This means that the ability of the gas to not preignite is less important.
  4. May 7, 2016 at 10:57 AM
    #44
    Shelf Life
    Rob
    Central Oregon
    I'll try that when I go to Colorado next month.
  5. May 7, 2016 at 11:13 AM
    #45
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Thanks for posting this info @ziggynagy
    I'd be curious to see any testing that shows the difference in HP/Torque of a 2nd gen running 87 vs 91. Anybody see any charts or write ups on this? I'd consider running 91 on certain road trips when I'm loaded up heavy with my slide-in camper and gear going over the mountains.
    Norton likes this.
  6. May 7, 2016 at 7:45 PM
    #46
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Supercharged and turbo motors still need the higher octane right?
  7. May 8, 2016 at 7:34 AM
    #47
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Have made several trips from Memphis to Colorado over the years, never had a problem with the lower octane fuel while there. One thing I recommend is fill up with lower elevation fuel (ie 87 or higher) as soon as your return to lower altitude coming home, to reduce the chance of pinging from the lower octane/high elevation gas.
  8. May 8, 2016 at 3:12 PM
    #48
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Yes and, most likely, cooler spark plugs.
  9. May 8, 2016 at 3:39 PM
    #49
    Pigpen
    Dan
    Northwest Montana
    Because when I filled up this morning there was an 80 cent difference between regular and premium. If the cost could be justified, I would do it regularly. As of now, I only use premium (non ethanol) when driving long distances, often towing my camper, in the mountains.
  10. May 8, 2016 at 3:55 PM
    #50
    mattfromkingston
    mattfromkingston Member
    2013 dclb
    yep, higher cylinder pressures to create more torque/power make the fuel more volatile. the cooler plugs are a way to reduce the chance of preignition from the heat on the plug rather than the spark itself. i've been running 1 or 2 step colder plugs on my turbo cars for years. gapping them down tighter too can help too.
    My buddy experiences pinging on 87 but not on 89 octane. ive only had mine for a week i havent noticed it yet. the way the trannys like to keep you in overdrive and lug itself around at low rpm doesnt help motors are quite susceptible to knock at low rpm. for mpg id say you want to run the lowest octane without pinging. once the motor really starts to knock the sensor pulls timing reducing power and efficiency. when towing or loaded down its probably better to run high octane to keep the motor off the knock sensor and running as much timing as possible for power/tq output. remember that torque output dictates fuel consumption. if you are looking to make some power/tq, its going to use up some fuel...
