2nd Gen Regular versus Access Cab for leg room; Is it different?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lightfire, Nov 21, 2009.
  1. Nov 21, 2009 at 12:22 PM
    lightfire
    lightfire [OP] Well-Known Member
    Is the leg room for the regular cab different (less) than the access cab? I know it is for 1st gen as I have had both but can't find a regular cab 2nd gen to try.
  2. Nov 21, 2009 at 12:23 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    my neighbor has a regular cab and there cabs look like there a few inches longer, IDK but thats what i see
  3. Nov 21, 2009 at 12:39 PM
    SwampThing07
    SwampThing07 Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    Ive had both. Access cab seems to have more leg room.
  4. Nov 21, 2009 at 1:09 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    My reg cab has more leg room than the silverado crew cab i had before. I'm 5'11" , I still have 2 or so clicks left behind the seat and have to reach the clutch just a bit.
    Can't speak for the DC or AC though, even though I test rode an access cab, just don't recall.
  5. Nov 21, 2009 at 2:01 PM
    Yota1
    Yota1 Well-Known Member
    i am 5'10, and found both to have lots of leg room, and i needed to slide forward in both trucks to be at a comfortable driving distance.
  6. Nov 21, 2009 at 2:06 PM
    lightfire
    I am 6" 2" and I can say for sure the first gen reg cab sucks for my leg length - very cramped, whereas the first gen access cab is OK. Don't want the same thing to happen, but I found a used reg cab a days driving distance and want to make sure before I go to that much trouble.
  7. Nov 21, 2009 at 2:12 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Im 6' I have my seat moved one click forward from completely towards the back. Access Cab should have a bit more leg room and be more comfortable since reg cab seats don't recline unless you are one of the lucky ones with bucket seats in a regular cab.
