2nd Gen relay for constant power at power outlet... can't locate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaInTx, Oct 21, 2018.
  1. Oct 21, 2018 at 10:43 AM
    TacomaInTx
    TacomaInTx [OP] Well-Known Member
    Roger
    Eddy, TX
    2012 DCLB 4x4 TRD Sport Tacoma
    Bilstein 5100 all 4 corners, OME 886 front springs, adda leaf progressive rear packs. Front upper control arms replaced also ,Group 31 battery conversion with Odyssey gel battery . Warn winch bumper and winch. Prinsu roof rack,Full grille replacement with ridgid duallys mounted behind, and 17" SCS bronze wheels with copper 255/80/17 ,
    OK, I must be handicapped while searching :( I have a 2012 TRD and have relay/fusebox under hood open. Want to use pigtail to short relay for constant power at outlets. NONE of my relays are labeled POWER OUTLET like in the posts for 1st and 3rd gens :( Am I missing something. Thanks for helping the dummy having a "Senior" moment ;)
  2. Oct 21, 2018 at 11:29 AM
    Muddinfun
    Muddinfun Well-Known Member
    Norton and stickyTaco like this.
  3. Oct 21, 2018 at 12:07 PM
    TacomaInTx
    Roger
    Eddy, TX
    Muddin Fun... I thank you very much!!!! (you can't see me bowing) Not sure what you used to find this but THANKS!!!!!
    Muddinfun likes this.
  4. Oct 22, 2018 at 4:48 AM
    TacomaInTx
    Roger
    Eddy, TX
    Think we can put a jumper in like other gens? rather than mess with the relay?
  5. Oct 22, 2018 at 10:21 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    In theory, yes, but the jumper would have to replace the relay, bridging the same connection that's soldered here. IMO, soldering is easier than figuring out the correct pins and making/installing a jumper that doesn't fall out or short-out something else after you close-up the dash.
    Trust @ramonortiz55 - he does good work!
  6. Oct 30, 2018 at 1:17 PM
    TacomaInTx
    Roger
    Eddy, TX
    OK finally had a chance to complete the mod. I wedged a piece of plastic instead of soldering. I have NO IDEA how I would have figured out where the relay was without the help here THANKS!!!!!
