2nd gen Ride quality
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMTrailRider, Nov 30, 2017.
  1. Nov 30, 2017 at 5:45 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    I've got a 2014 DC 4wd. From the time I got it new... it rides "soft". I'm sure you know what I mean. Built for comfort, basically. I do a lot of hiway driving, but also spend time in pastures, in corn stubble, secondary roads, basically farm country.
    What are my options if I want to stiffen up the suspension? I wouldn't be doing any work myself. I'm not really a "car guy" when it comes to mechanical stuff. I don't want to invest $2k. But if I could stiffen up the suspension by something simple like new shocks at a local shop, I'd do it.
    I spend a lot of time in the detailing sub-forum, but not as much time in the 2nd gen Forum. So I don't even know where to begin searching for my answer.
    So. Can you help me out? Is New shocks and leaf springs the direction I should go? Thanks.
    Benzdriver81 likes this.
  2. Nov 30, 2017 at 5:51 PM
    Pigpen
    Dan
    Northwest Montana
    You're going to get all of the same answers as if you asked, "what's the best lift..."
    And I know you've read those threads.
    If you don't want to lift it, go with 883 coils instead of 885s
    ChemDawg and NMTrailRider[OP] like this.
  3. Nov 30, 2017 at 6:22 PM
    NMTrailRider
    New Mexico
    Ha yeah I hear ya. Nope I don't want a lift. Just want a stiffer ride that feels like an older 4x4 and not a Camry.
    So it's shocks + coils that I need? And not just shocks?
    Would a new leaf pack stiffen up the back end? Or just shocks?
  4. Nov 30, 2017 at 6:28 PM
    Pigpen
    Dan
    Northwest Montana
    Shocks won't stiffen anything. You'll need a leaf pack and shocks. I'm sure Deaver would set you up with a nice zero lift stiffer leaf pack. I've heard of a couple folks buying Dakars and removing the upper overload spring (there are 2) as well as the third leaf from the top. You could probably sell the ones you pull pretty easily, but I'd just do a custom pack to be assured you're happy with the ride.
    NMTrailRider[OP] likes this.
  5. Nov 30, 2017 at 6:28 PM
    NMTrailRider
    New Mexico
    Already done.
  6. Nov 30, 2017 at 6:53 PM
    NMTrailRider
    New Mexico
    Its sounding like to achieve what I want (stiffer suspension)... I'd basically be doing the exact same thing as if I were doing a 1" or 2" lift (but 883 instead of 885 and different leaf pack).
    And if I'd appreciate an inch or two of lift... I might as well do it now because it could essentially be a "side effect" of what I'm wanting to do to the suspension anyway.
    An inch or two lift would be great. I never thought about doing it because of expense. But it's really not a cost at all if I'm wanting a different suspension anyway.
    So... 885's, 5100's on 4 corners and a new leaf pack. That'll get me an inch or two of lift and a slightly stiffer ride.
    Am I on track with my thinking?
    LivinLoud likes this.
  7. Nov 30, 2017 at 6:55 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Hell, if you want stiff just throw in some front coil spacers and a rear lift block. 250$ later and it rides like a 75 chevy with a 6" lift kit.
  8. Nov 30, 2017 at 7:03 PM
    NMTrailRider
    New Mexico
    Is this real advice or being facetious? Ha I can't tell, sorry!
    Skyway likes this.
  9. Nov 30, 2017 at 7:03 PM
    Pigpen
    Dan
    Northwest Montana
    You're right on track. 885s gave me the exact same lift as 5100s set at 1.75" setting on stock coils.
  10. Nov 30, 2017 at 7:05 PM
    Pigpen
    Dan
    Northwest Montana
    He's humorously suggesting you want your truck to ride like shit
  11. Nov 30, 2017 at 7:07 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    A very small coil spacer lift and 1” rear blocks?
  12. Nov 30, 2017 at 7:09 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    You can order a custom leaf pack from Alcan. Order as little as zero lift. You can also order heavier duty leafs (thicker) for more load capacity.
  13. Nov 30, 2017 at 7:13 PM
    NMTrailRider
    New Mexico
    What setting on the billsteins on the 885's?
  14. Nov 30, 2017 at 7:17 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Bilstein 4600 shocks will firm the ride up without leaf packs and coils.
    BillsSR5 and NMTrailRider[OP] like this.
  15. Nov 30, 2017 at 7:18 PM
    NMTrailRider
    New Mexico
    And that would get me a stiffer ride all around at less cost. Hmm...
  16. Nov 30, 2017 at 7:19 PM
    T Fades
    Simi Valley, CA
    Always keep billy’s at 0 with any spring
    Let the coil do the lifting
  17. Nov 30, 2017 at 7:22 PM
    TACO TX
    Kelly
    Denison ,Texas
    The valving is not as soft as a factory shock, you wont feel the body roll and sway and will have better handling on the street as well.
  18. Nov 30, 2017 at 7:23 PM
    NMTrailRider
    New Mexico
    So Billie 1.75 on stock coils is doable but not advisable?
  19. Nov 30, 2017 at 7:24 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Bilstein 5100's set at 0 with Eibach 112620 coils will give you 1.6" lift and a nice stiff ride plus pretty well level the truck. Add a single leaf AAl in the rear and you'll stiffen that up and get your factory rake back.
    RogueTRD and NMTrailRider[OP] like this.
  20. Nov 30, 2017 at 7:26 PM
    NMTrailRider
    New Mexico
    When you say "pretty level", will the front still sit slightly lower than the rear?
    Casper66[QUOTED] likes this.
