2nd Gen Starter Problem - Starter? Relay? Gremlins?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HBMurphy, Oct 16, 2015.
  1. Oct 16, 2015 at 10:04 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I have replaced my starter for the third time since I purchased the truck new.
    I have a 2009 4.0.
    The first starter replacement was around 40,000. Replaced it with a rebuilt one. That was good until about 84,000 miles and I replaced it again. Then a few days later it wouldn't start again. Made sure there was good voltage (I have two batteries and they both were 12.6-12.7). I made sure that all connections were clean - including the terminals at the starter.
    I then swapped the starter relay that looks like this:
    Bam - started like a champ. ...up until today (about 3 weeks after changing the relay and the starter). So I took the original relay, plugged it in and, once again it started with no problem. The truck has been very reliable but this is a bit puzzled and feeling a bit insecure since I'm on my way to Mexico next week.
    As I am going thru my trail spares I pulled out my original starter and looked at the plunger and contacts and thought there was no reason that shouldn't have worked. Bench tested it and it was fine.
    I welcome anyone with any constructive ideas or entertaining posts to please chime in. I want to feel confident that I will start. I would love to hear someone that had a similar problem and found a permanent solution to the same problem.
    Thanks in advance.
  2. Oct 17, 2015 at 12:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you installing autopart store rebuilt starters? That can be an issue all on its own.
    How old is the battery? Just because it reads good in an idle state doesn't mean that it has the cranking power. Have it load tested by a reputable shop.
    Read the battery voltage when starting and see how far it drops. That will tell you a lot.
  3. Oct 17, 2015 at 7:03 AM
    HBMurphy
    Paul
    So California Coast
    None
    I more than understand about the rebuilt biz - most are JUNK. The batteries are Oddesy Mfgd DieHard Platinum 1 year old.
    Good point on measuring the voltage on starting - I will do that next time it happens
    My thoughts are if it was a bad starter, swapping the new relay with the old, or vice versa (I've done the swap a couple of times and each time the issue goes away - for a while) shouldn't make a bit of difference.
    Thanks for your input.
  4. Oct 17, 2015 at 7:22 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Maybe check the starter's "solenoid" as well? Could be that's what was part of what's causing the problem? Yes, even though you switched out the original "Starter" with a "remanufacturerd" one but as previously stated, it's not an original-it was an autoparts rebuilt one.
    This is my advice and yes it will be a bit of money but still you will have covered just about everything with starting your Tacoma?
    Change/buy all parts brand new from Toyota:
    1.) Starter
    2.) Relay
    3.) Battery
    Also make sure that your battery cable connectors are clean'd real good as well as the cable and connector that connect to the Starter/Solenoid.
    If problems still presist then looks like you'd have to take it in to Toyota to determine exactly what is the ROOT CAUSE of problem?
    Good Luck and post back on your findings? I'm now curious on the out come.
  5. Oct 17, 2015 at 11:16 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Maybe the relays' connection in the fuse box is the cause? Or the wire connections under the fuse box to the box itself are loose or corroded?
  6. Oct 17, 2015 at 12:29 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    A friend had similar problems on his Rodeo and it turned out to be the ignition switch.
  7. Oct 18, 2015 at 9:09 AM
    HBMurphy
    Paul
    So California Coast
    None
    Good points.
  8. Oct 18, 2015 at 1:51 PM
    Toy4me
    Tom
    NNJ
    If it happens again, try wiggling the relay, and also the wiring harness that goes into the fuse box. If that doesn't do it , just unplug and plug back in the same relay without swapping. Similarly check the ignition switch and it's plug in the harness. At least they're free, easy and clean to try. Good luck.
