2nd Gen. starting problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by frevilleb, Jun 14, 2020.
  1. Jun 14, 2020 at 9:26 AM
    frevilleb
    frevilleb [OP] New Member
    Brandon
    My 2012 Tacoma has a starting problem. After it runs and sits for 2-4 hours, I will go in and start it, and it would hesitate when starting. But when it starts, it runs and drives fine. Someone told me it could be the oxygen sensor failing, but I haven't changed it out yet, since it has 4 sensors alike.
    Has any one else have this problem?
  2. Jun 14, 2020 at 10:16 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Sounds like fuel pressure bleeding off... Had a 1999 S10 4 banger where the fuel pressure regulator was starting to shit the bed that was bleeding down fuel pressure, would do the same thing.
    12TRDTacoma likes this.
  3. Jun 14, 2020 at 11:15 AM
    frevilleb
    Brandon
    It doesn’t sound like it would be fuel pressure. In the mornings, it starts fine. It only hard starts when it’s hot out, above 85 or so.
    I would post what it sounds like, but the extension is not acceptable.
  4. Jun 14, 2020 at 11:25 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Actually, it does.
    Hook up a fuel pressure gauge and leave it there to see if the pressure is bleeding off over time. That will be your ticket to ruling fuel pressure as a problem or not.
  5. Jun 14, 2020 at 1:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When you say it hesitates, is it not even cranking? Is it an extended crank time before it runs on its own?
    TnShooter likes this.
  6. Jun 16, 2020 at 6:17 AM
    frevilleb
    Brandon
    It cranks and runs after about 6 to 7 seconds. It starts and runs fine when I get in first thing in the morning. If I get in 4 hours after it has been running, it hesitates, but does start. I am looking to see if someone I know has a fuel pressure gauge, so it may be a few days.
  7. Jun 16, 2020 at 6:44 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    An EVAP purge on hot start up causing rich A/F ratio is common when fuel is topped up to max when refueling.
    When the pump click off STOP. Do not try to pump more fuel in tank.
  8. Jun 17, 2020 at 1:32 PM
    frevilleb
    Brandon
    I called Toyota and they gave me pricing and how long it will take to do it, but they also told me to try a fuel additive. I will try that to see if it clears up a little.
    I did try to call a few other places, and they were not very helpful.
  9. Jun 17, 2020 at 2:58 PM
    durtkillon
    durtkillon Well-Known Member
    Kurt
    Fort Collins, CO
    2010DCLBV64X45SPAT 1E7 BASE
    Sickest Mod: Synthetic Oil
    Well the good thing about oxygen sensors is that they have a value and can be diagnosed easily. Any codes or mil's? Does it smell of gas during hard starts?
    These types of problems can be really hard to track down, but I think the suggestion to do a fuel pressure bleed off test would be a good place to start. If you had a leaking injector (to the intake), it could cause loss of pressure and flood the offending cylinder. At least there is a way to rule it out.
    It wouldn't hurt to clean the MAF. If you use a K & N filter especially. A bad MAF has been reported to cause long cranking starts.
    You may want to read this thread: https://www.tacomaworld.com/threads/long-crank-issue-when-starting.499171/
