2nd Gen Steering Wheel Slop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brringler813, Apr 25, 2019.
  1. Apr 25, 2019 at 7:33 AM
    brringler813
    brringler813 [OP] Member
    2010 Tacoma 4x4 Off Road
    My 2010 Tacoma 4x4 TRD OR seems to have a lot of play in the steering wheel. When I'm driving, especially on the freeway, it feels as if my truck is "floating" because of the deadspot between 11 o'clock and 1 o'clock. If I need to make small adjustments to the direction I'm traveling I have to rotate my steering wheel all the way to one side until it engages, then all the way to turn the other way. Anybody else have this problem? I just put in a brand new steering rack, but I also have aftermarket upper and lower control arms with uniballs making the steering a bit stiffer. This seems to cause my truck to follow grooves in the road very easily and force me to wander across the road. Any ideas?
    Fendergeek likes this.
  2. Feb 11, 2020 at 5:53 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    Sorry to bump an old thread, but I'm having this same issue. I have done the "steering wheel fix" to shorten the intermediate steering shaft but no dice. Anyone familiar with this issue? Not so much the clunking off road (mine has it too) but the looseness of the steering wheel driving even on normal roads?
  3. Feb 11, 2020 at 6:00 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    uca, lca, and tie rods all have no play?
    Ricardo13x likes this.
  4. Feb 11, 2020 at 6:14 AM
    DG92071
    DG92071 Well-Known Member
    I'd first question if there's worn steering components. If everything looks good it has to be the alignment.
    Kolter45 likes this.
  5. Feb 11, 2020 at 7:42 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Could be the intermediate steering shaft. There's a small ujoint in there that wears over time. I've chased down and replaced every single component but still have slop myself. I replaced lca, uca, steering rack, inner/outer tie rod, sway bar endlinks, sway bar bushings, wheel bearings, cam alignment bolts to no avail.
    I will be pulling off the steering shaft soon to investigate. I may even run a small weld on the telescoping part of the shaft per a few diys I have seen in the past few months and replace ujoint.
    Fendergeek, 03coma and Alexely999 like this.
  6. Feb 11, 2020 at 9:24 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    x2
    The steering shaft u-joint is exposed and wears out. Have someone move the steering wheel back and forth and look under drivers side to see if the play is coming from the u-joint in the steering shaft.
  7. Nov 8, 2023 at 9:22 AM
    Fendergeek
    Fendergeek Active Member
    Denver, CO
    2013 Tacoma TRD
    Any updates on this? I replaced my lower intermediate shaft with a $60 part (not the $200 OE part) and still have the wandering feeling. Tried taking apart the steering column to see if anything can be welded but it's the telescoping steering wheel and not sure how to measure the right distance when out the truck. Is the redesigned telescoping steering shaft as susceptible to play as the older 1st Gen Tacomas where the weld mod was common? My truck is exhibiting that same problem at 300k miles and I've similarly replaced just about everything at this point.
  8. Nov 9, 2023 at 11:45 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    My frame was bad, Replaced whole front end and still wandered after and drove it for a few months until I found the weld by pass cab mount was able to be pushed in with my fingers.
    Did you check your rear shackle bushing and ubolts for being tight? Tire pressure in rear OK? That helped a lot but not enough
  9. Nov 10, 2023 at 5:14 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    Oh man, that's not fun. What part was cracked and how did you determine that the frame was bent? I saw you're doing a frame replacement, was fixing the bend less economical than replacing?
    I'll check the rear leaf shackle and U bolts. I've replaced so many things trying to track it down. Hopefully the frame isn't the issue but every alignment the cam tabs are at different positions right and left so that seems to indicate an issue with the frame. Alignment numbers are similar for both sides.
  10. Nov 13, 2023 at 6:41 AM
    knottyrope
    Knotty
    Bahstun
    Frame rotted too much to be repaired.
    Ill get some pics when there is some day light.
  11. Nov 21, 2023 at 9:46 AM
    Elikk
    Elikk Well-Known Member
    Eli
    Tacoma Trd sport crew cab 2011
  12. Nov 21, 2023 at 10:04 AM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
  13. Nov 21, 2023 at 10:07 AM
    Elikk
    Eli
    Huh, weird it's listed under the 2011 taco parts
  14. Nov 21, 2023 at 10:10 AM
    lr172
    ‘11 DCLB 4.0 Auto
    Yes, it is listed as the "intermediate shaft." The part that usually fails is the "lower intermediate shaft." You will notice that rock auto lists both of them for the 2nd gen. The one you linked is the one that goes through the firewall and connects to th steering wheel, not the one that connects to the steering rack. The one you listed has the ujoint in the cab, so doesn't rot away, like the one in the engine compartment. Not saying that this one can't go bad as well, but because the u joint doesn't see the elements it is likely to last a lot longer.
  15. Nov 21, 2023 at 10:13 AM
    Elikk
    Eli
    I'm getting the infamous slop and knock that's coming from the upper one I think, the bottom one seemed fine in the u joint since there's no substancial slop in the wheel it's just clunks over bumps, all the front end components are new
  16. Nov 21, 2023 at 10:17 AM
    lr172
    ‘11 DCLB 4.0 Auto
    sorry then. seems like you got the right part. No experience ot offer, as in my case the lower one failed.
  17. Nov 21, 2023 at 11:21 AM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    Same here. I replaced the upper intermediate shaft with the new, updated design and no difference. FWIW: I have that Dorman shaft on my 07 FJ Cruiser and it has zero issues with steering wander. It has a 2" lift but stock tires. Wondering if the tire offset on my Tacoma is contributing to this issue.
  18. Nov 21, 2023 at 11:40 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I have a similar dead zone in my steering wheel on my 2012.
    I've got a lot of aftermarket parts, pretty much the whole front end is different -- so hard to say if my problem is the same as others. All new bushings and joints etc in the front suspension, new tundra steering rack, new inner/outer tie rods, as well as a new lower intermediate shaft.
    Pretty much the only thing I haven't replaced is the upper intermediate.
  19. Nov 21, 2023 at 12:12 PM
    Fendergeek
    Denver, CO
    2013 Tacoma TRD
    We should isolate the problem. For those with the steering wander, do you have the Total Chaos heim joint style UCA? Wheel offset? My thought is that we all have checked or replaced the steering components recently so it has to be something either in the steering column/shaft or possibly wheel/tire combo with the stiffer UCA.
  20. Nov 21, 2023 at 7:23 PM
    Sterling_vH111
    Sterling
    socal
    Not TC ones, but LT arms with heim joint UCA pivots. Might outer tie rods are Heims as well, with brand new Moog inners. Uniball pivots for every other joint — No bushings, so it’s solid. Even my steering rack has solid aluminum bushings.
    Intermediate shaft is new… my only guess is that my steering rack has some play internally or that the upper intermediate/rag joint is shot. The upper shaft doesn’t seem loose or overly worn or anything if I pull on it or grab the steering wheel & turn back and fourth with vehicle off.
    Fendergeek[QUOTED] likes this.
