2nd Gen Stock Headlamps with Aftermarket HID Bulbs - Pics Wanted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xodeuce, Nov 13, 2009.
  1. Nov 13, 2009 at 5:10 PM
    xodeuce
    xodeuce [OP] mmmmmmbourbon.
    Alabama
    2004 UZJ100
    I've seen a lot of pictures of HID bulbs in aftermarket projector housings. Does anyone have night pictures of them in stock headlamp housings. I'm looking for as many color temps as possible. I couldn't find a thread with pics.
    The reason I ask, is that I've heard that projector lenses tend to make things look more blue-ish due to dispersion and refraction at the edge of the beam pattern. I read somewhere online that it's not as pronounced in non-projector lens housings, so where a 4300k bulb might look rather blue in a projector, it will look different in a reflector like the ones in our stock headlamps.
    Thanks!
  2. Nov 13, 2009 at 6:24 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    It is hard to take photos when the HID is ON.
    It have to see it by yourself. I have 6000K H/L Beam. It work great, but under one condition, the buldsonly great for about a year & half, than it will not that bright, but it is still brighter than the OEM lights.
  3. Nov 13, 2009 at 7:19 PM
    xodeuce
    Alabama
    2004 UZJ100
    <threadjack>
    I was under the impression that the service life of a HID bulb was considerably longer than incandescent?
    </threadjack>
  4. Nov 13, 2009 at 7:22 PM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Why? If you are gonna do it...do it right! http://www.toyotanation.com/forum/showthread.php?t=318172 And what your heard is wrong.
  5. Nov 13, 2009 at 7:33 PM
    xodeuce
    Alabama
    2004 UZJ100
    I don't want to spend that much time or money on it.
  6. Nov 13, 2009 at 7:38 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Here ya go! :D (Sorry for the crappy pic's)
    AGT 6000k Hid's.
  7. Nov 13, 2009 at 7:43 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Wow that is incredibly irresponsible and unsafe to run them without protectors...not to mention illegal
  8. Nov 13, 2009 at 7:46 PM
    wing103
    Boston
    At this time, they still dose. But you have to think what you pay for. Old days I have to pay 550.00 for a dual beam HID, now only 200.00
    So what you think!!
  9. Nov 13, 2009 at 7:48 PM
    xodeuce
    Alabama
    2004 UZJ100
    According to many people on here the bi-xenon bulbs have precisely the same beam cutoff as halogen bulbs in a stock housing. Is that misinformation? Perhaps this would be better suited for the lighting forum.
    Edit: I figured it was manufacturing cost coming down.
  10. Nov 13, 2009 at 7:50 PM
    dktaco
    Josh
    I will cost as much with a lame PNP kit and after market projector headlights. I am saying for my retro now. And yosh is gonna help since he is local.
    Where are the cutoff lines on a wall?
  11. Nov 13, 2009 at 7:52 PM
    dktaco
    Josh
    Wrong...horrible glare, hotspots, etc. Not to mention horrible thrown light. You need to do it right by doing a complete HID retro as I mentioned above.
  12. Nov 13, 2009 at 7:57 PM
    xodeuce
    Alabama
    2004 UZJ100
    From the thread over at toyotanation:
    $225 - projectors and ballasts
    $35 - bulbs
    $100 - nearly new headlights
    $100 - other misc stuff.
    That's far more than a PNP kit.
    Edit: I guess if you throw in an aftermarket housing you're approaching that cost. I don't want new housings though.
  13. Nov 13, 2009 at 9:04 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    its not the pic quality, they are just that crappy to begin with, not much you can do about it!!;)
    i feel so honored to be linked!
    OP, here is a color chart FYI...
    http://www.driveaccord.net/forums/attachment.php?attachmentid=16734&stc=1&d=1228547906
  14. Nov 13, 2009 at 9:15 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    They're illegal regardless if you put them in the stock halogen housings or if you do a complete projector retrofit.
    As far as the OP's question, the actual color temp isn't going to change. It will look the same on the road. If you had 4300k bulbs in actual HID projectors than yes depending on the angle you look at them from you will get that purplish/blue color that you see with the Audi's, BMW's, etc. But if you look at them straight on, it's still pure white light. The projector just refracts part of the light beam and you only get the blue part of the light spectrum depending on how you look at it. But your color on the road is the same.
    I had a kit in the Impala SS I had with the stock halogen housings. Glare wasn't an issue with those lights. Light didn't get dispersed all goofy. Some cars are really bad though. I'd never put HID's in a truck without projectors since it sits up higher and would be more prone to blinding someone. Also, regarding goofy light dispersion, if you get cheap ebay projector lights they usually disperse the HID's light a lot worse than the halogen housings would. So if you're going to go HID you should really just do an actual retrofit with actual HID projectors. Still not technically street legal though.
  15. Nov 14, 2009 at 1:45 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    I have had my hid's for about 6 months now and have never had anyone flash me or anything. My friends in there cars and trucks drive by me at night and they never said anything about being blinded by my lights. Yes i know its not as good as a "retro fit" but when you can give me a few hundred dollars then i will do it. I plan on doing it sooner or later but i dont have the money right now. And if i were to get flashed all the time or told they blind people, I would simply put the stock ones back in place. But that has not happened yet so there staying were they are. And the retro fit also looks badass haha. But i will try to post pics later tonight of the cut off beam if i can. Im useing my phone cause my computer isnt working so i will if i can.
  16. Nov 14, 2009 at 2:04 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    I am currently running 8K HID Projectors in my headlights that I got painted BSP to match the truck...I am also running 8K HIDs in my fogs...I got them off my buddy who owns Luminous Solutions...
    I can get pictures when I get off of work today at 5pm (in 3 hours)...I will update my post later...I do have pics of the HIDs installed but not on if you would like to see...just let me know...:)
  17. Nov 14, 2009 at 2:15 PM
    Joelito2983
    Joelito2983 Well-Known Member
    This is my setup when i had 5k 50w hid, but now im running 8k didnt really like the cream look....
  18. Nov 15, 2009 at 7:42 PM
    jtav2002
    Josh
    Reading, PA
    I loved the 5000k kit I had in my Impala SS. Then again I was going more for function over form. Not a fan personally of anything over 6000k.
