2nd gen suspension on a 3rd gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdGenSR5, Dec 25, 2019.
  1. Dec 25, 2019 at 10:03 PM
    3rdGenSR5
    3rdGenSR5 [OP] New Member
    Clayton
    2017 Quicksand Tacoma SR5 access cab
    None so far
    Hello all. Been kicking around the idea of lowering my 3rd gen on air ride suspension. I know, it might seem sacrilegious to some. But I’ve seen a handful of renders online and I’d like to dive down that route. As there isn’t a lot of information online that I’ve found or pre made kits for this. I was wondering if I’d be able to piece together a kit from a 2nd gen Tacoma to at least get me close to a working air ride. I know fabricating a fitting will be necessary but I’d like to not have to start from scratch if possible. If the mounting points are way off I’ll just wait until I have more time and money to build from scratch but I’m a bit impatient. Any information on this would be much appreciated.
  2. Dec 25, 2019 at 10:05 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    2nd gen suspension will fit on a 3rd gen. Putting 3rd gen front coils on a second gen will lift a 2nd gen 1”, so the opposite should lower a 3rd gen 1” in the front only. Hope this helps.
    Bishop84 likes this.
  3. Dec 25, 2019 at 10:35 PM
    Bishop84
    Bishop84 Well-Known Member
    They are the same truck, it will work, and as mentioned will immediately lower the truck by 1" by OEM standards.
    I don't know how low you can get a 3rd gen, but the rear is super easy, just do an leaf spring flip.
