2nd Gen taco Auxiliary Fuel System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Primitive_Machinist, Oct 7, 2022.
  1. Oct 7, 2022 at 2:14 PM
    Primitive_Machinist
    Primitive_Machinist [OP] Member
    2012 DCLB Silver Tacoma 4x4
    Hi All,
    Ive been lurking and searching for a fuel system that fits my needs. I've seen a whole buncha DIY in bed systems and a couple in the spare tire location build with alot of mixed results as to what they should've or would've done differently if they had a redo. In the bed transfer tank won't work for me with my other gear already occupying it. I came across the JD Fab aux fuel kit and was wondering if anyone here has an experience with it?
    https://jdfabrication.com/collections/05-15-6-lug/products/tacoma-rear-gastank-kit
    My current spare doesn't fit under there anyways so this is the ideal location for my needs. Any tips/ advice as to what tank to use where to tap into the OE fuel system and ways to avoid throwing codes?
    Sub_Par likes this.
  2. Oct 8, 2022 at 2:16 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Why not just install an LRA tank.
    paranoid56 likes this.
  3. Oct 8, 2022 at 2:47 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    Because that would be too easy
  4. Oct 8, 2022 at 3:20 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Post the question here. It’s where the JD guys and guys that use their shit are the most active.
    https://www.tacomaworld.com/threads...el-and-934-cv’s.626274/page-771#post-27899447
  5. Oct 8, 2022 at 8:19 PM
    Primitive_Machinist
    couple reasons for why not LRA, first is taco lean....... second is I can't source the tank and get it delivered in CA due to CA law.
  6. Oct 8, 2022 at 8:26 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    And you think the JD tank will pass smog? :rofl:
    6 gearT444E and whatstcp like this.
  7. Oct 8, 2022 at 8:44 PM
    Primitive_Machinist
    Not worried about passing smog, I'm talking about actually getting my hands on parts.
  8. Oct 8, 2022 at 9:35 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    you can order direct from Aus :D
  9. Oct 8, 2022 at 10:53 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    For the JD Fab products just call them. 760-740-0442
  10. Oct 9, 2022 at 10:56 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    TBH, I didn't know they made that. JD makes pretty damn good stuff.
    Pretty cool workaround for aux fuel tanks that you can actually buy in CA. It is spendy but I now sort of want one to use as underbed storage (spare is on my rear bumper so there is just a big empty space down there).
  11. Oct 11, 2022 at 9:25 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    $1200 and it doesn't even include the tank? They're just selling a "frame" for mounting a tank that you'd have to have custom made? Sorry, that's absurd.
    goforbroke123 and reallifedog like this.
  12. Oct 11, 2022 at 5:23 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    But it’s JPFap, everyone gets a load off to their goodies.
    fatfurious2 likes this.
  13. Oct 11, 2022 at 9:29 PM
    Primitive_Machinist
    any recommendations of a fabricator that can do something similar for less?
  14. Oct 12, 2022 at 7:09 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    I would imagine your local sheetmetal shop would be able to do it cheaper. I know the one I worked at last would do that job for ~$600
  15. Nov 20, 2024 at 1:23 PM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    search sank into the sand up to the axles at this point .
    The options for auxillary fuel tanks is woefully dismal
    I guess my 3 gallon kolpin is going to have to make do
    the range on these teenie weenie tanks is terrible ( and unsafe for adventuring )
  16. Nov 20, 2024 at 1:27 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    JD's tank box wouldn't need to pass smog unless you removed the OEM tank and used it as the primary fuel source.
    reallifedog likes this.
  17. Nov 20, 2024 at 2:36 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    I've got an F150 rear tank I'm going to hang in the spare location. It fits really nicely. I'm just working out some finer details(filler neck location, etc.) before I get serious.
  18. Nov 22, 2024 at 9:55 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    sounds good ! the ONLY viable option seems to be self fabrication, that JD fab thing is silly , link recommends a chevy truck tank in their cradle , but a few straps bolting it in place would cost about $50 instead of thousands for their silly "cradle".
    even strapping an outboard boat tank in front of the spare tire would be a better option
    the Facet 40171 fuel pump is low pressure and has a built in check valve and would make a great transfer pump and would need to tap an inlet into the stock tank
    Would have to be removed to pass fascist state emissions restrictions if you happen to live behind enemy lines in a place like CA
    one of my biggest annoyances about the Tacoma is the fuel range, seems like I am constantly having to stop for gas and change route plans to get gas while exploring (never pass gas in the desert while in a tacoma ) , I suppose just commuting to work it would be OK having to get gas 3 times a week.
  19. Nov 22, 2024 at 11:14 AM
    paranoid56
    San Diego
    14 double cab taco
    I have yet to have cali bitch about an aux tank. they arnt looking at things like that. i have also had no issues with my long range tank in my taco either. they plug it in 10min later i am out. very similar to deq
  20. Nov 23, 2024 at 8:02 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    Yeah that's good advice. I'm trying to keep the cost low(<$500) and have the necessary fabrication experience so that should be attainable.
    I wasn't going to mess with the tank at all and probably modify the filler neck somewhere to plumb in the transfer. My biggest concern is the dreaded p0456 for a vacuum leak so a pump that seals off is ideal. I'm not sure a check valve is what I need as it will bleed under vacuum. I was considering using the stock f150 pump as it also has a built in sender making wiring a gauge super simple and adding a solenoid inline that opens when the fuel pump is powered.
    I'm not sure if that is necessary but we'll see. I guess I could just pull vacuum on the pump itself and see if it holds.
