2nd gen taco thermostat upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Solomon_H, Apr 29, 2024.
  1. Apr 29, 2024 at 10:22 PM
    Solomon_H
    Solomon_H [OP] Member
    Solomon
    2014 Tacoma
    Hello, has anyone upgraded their thermostat from a 180° to a 160° and been hit with a check engine light?
  2. Apr 29, 2024 at 10:30 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Why would you want to go to a 160° thermostat?
    There's no need, not to mention your gona use more fuel because the fuel map is richer below operating temp.
    Torspd, b_r_o, SR-71A and 1 other person like this.
  3. Apr 29, 2024 at 10:30 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Why do you consider that an upgrade? Engines are engineered to run at a certain temp. If your engine doesn't reach that temp it won't run as efficient. I don't know if that would throw a code but it might.
    SR-71A and Dm93 like this.
  4. Apr 30, 2024 at 12:48 AM
    TacoTuesday1
    FL
    Why
    People have not had success with them
    the hotter the engine is, the more efficient it is
    Which is why it’s not efficient. Because 180 is not hot.
    when it is cold you burn more fuel to warm up faster and reduce emissions. It will burn even more fuel if not all the time.
    When it opens, coolant cools with the radiator and fan. It cools it. Not fails to cool it. It is not a radiator the size of a shoe with a Best Buy computer fan.
    vehicles with more power creating heat such as twin turbo simply have more coolers. With controlled valves that stay closed during warm up.
    Where cramped engine bays stuffing that in a small passenger car is a factor. Not a thing on the Tacoma factory engine.
    don’t know about supercharged applications.
  5. Apr 30, 2024 at 7:11 AM
    Solomon_H
    Solomon
    2014 Tacoma
    I have a supercharger and I find that I’m doing a fair bit of towing. Used a scanner and found that the code was telling me that the engine was running rich. Thank you for the responses
  6. Apr 30, 2024 at 7:15 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Better a little rich than lean. That’s for sure with boosted engines.
  7. Apr 30, 2024 at 7:21 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A cooler thermostat isn't gona help you there, in fact it will make it run richer yet.
    If your getting a rich code you need to figure out why instead of modufying things to attempt to compensate for it.
    Are you running a stock intake?
    Is it tuned?
    SR-71A likes this.
  8. Apr 30, 2024 at 7:23 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    A CEL code, or fuel trims? If a code, diagnose and solve that problem. Dont mess with the T-stat
  9. Apr 30, 2024 at 7:25 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    You can ask in the supercharger thread. @Torspd might know
  10. Apr 30, 2024 at 7:34 AM
    Solomon_H
    Solomon
    2014 Tacoma
    Stock intake, no tune and CEL code.
    My guess is that by changing the T-stat the engines running cooler and as such richer than before. I’m probably gonna switch them back once I get home and see if that does the trick.
  11. Apr 30, 2024 at 8:36 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you are running a supercharger and have the stock toyota TRD tune for said supercharger you should have zero issues.
    Running a cooler tstat is going to only create problems.
  12. Apr 30, 2024 at 8:43 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    What's the CEL code first?
    I've ran the URD colder thermo and now use the Motorad thermo. And haven't thrown any CELs with them.
  13. Apr 30, 2024 at 8:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do not do the 160°. 170° max.
    The 160° can create a problem with reaching the proper engine temp, and the ecu will then throw a code. May even run more rich.
    SR-71A and SUMOTNK like this.
