2nd gen tacoma. 07 6spd. 207k miles MPG concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MugenNeuspeed, Jul 14, 2023.
  1. Jul 14, 2023 at 8:45 AM
    MugenNeuspeed
    MugenNeuspeed [OP] Member
    joe
    2007 tacoma 4.0 6 spd
    I have 265/70/17 tires.
    It is stock, but lifted 2 inches.
    I baby this thing. I only get 14mpg.
    Is this accurate.
    No codes, all good.
    Anything else I can try?
  2. Jul 14, 2023 at 8:45 AM
    MugenNeuspeed
    joe
  3. Jul 14, 2023 at 8:49 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Seems a bit low, I'm getting 17mpg mixed local/country road driving w/ 265/76/16, also 4 door 6MT. Did your truck come stock with that size tire? If not, you need to account for the size difference when making your calculations. That could help a little.
  4. Jul 14, 2023 at 9:03 AM
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    Have you ever cleaned the throttle body or MAF sensor? Sparks? Airfilter?
    O'DubhGhaill likes this.
  5. Jul 14, 2023 at 10:35 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I have an 07, V6 - 4.0 with the 5 speed auto and run 265/70/16. Around town I get 17 mpg while on the highway it's 19 to 21mpg. The only time I've seen 14 mpg is pulling a trailer and driving 85 mph which is the speed limit on I-10 from Junction to El Paso.
    With the age of the truck, if you haven't, it's been a while or you don't know the maintenance history, you need start with what @PNW15 stated. New spark plugs, a clean the MAF and throttle body along with a clean air filter goes a long way for improved fuel economy. Also, @shaeff made a good point about the wheel size. Pretty sure 07's didn't come with 17" wheels.
  6. Jul 14, 2023 at 11:32 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The 4.0 will loose about 2 mpg to the gallon once you get close to 100k on the plugs. This combined with a dirty MAF and throttle body will pull the mpg down to 15ish.
    It would be nice to see your fuel trims.
    Just out of curiosity.
    BlkDakDave likes this.
  7. Jul 14, 2023 at 11:38 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    To add to the others, I'd bet the o2 sensors are ''lazy'' and well past time to replace if they never have been.
  8. Jul 14, 2023 at 6:40 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    This. I cleaned the air intake system from fender to throttle body and MAF with factory plug change. 20mpg highway, about 18 mpg mixed.
  9. Jul 14, 2023 at 6:47 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    What MPG did you get at 100k miles?
