2nd gen tacoma 3link
Discussion in 'Solid Axle Suspension' started by Pdugan6, Aug 5, 2019.
  1. Aug 23, 2019 at 4:28 PM
    #41
    Pdugan6
    Pdugan6 [OP] Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
    What kind of idiot had a plasma cutter and didnt use it for the front 2 crossmembers?...me. Once I get this one out I can tack on the link brackets to the frame. I am pretty sure I have everything laid out correctly ready to cycle.
    hoverlover likes this.
  2. Aug 26, 2019 at 8:14 PM
    #42
    Pdugan6
    Patrick
    Welded on the panhard bracket to the frame and cut and welded links and panhard. I think I’m going to pick up some solid 1”x3”x7”steel to make pads for my link brackets to sit on. With my frame at 22” right now and with my ruffstuff link brackets at 2”to center of bolt it only allows for 3” upteravel before the link hits the frame but with a pad I will gain maybe 1 1/4” uptravel. Little by little...
    3196D004-E623-47C6-B0AC-9966344B6565.jpg DF358014-F1F6-454E-BE04-8D7FEB994E9D.jpg
  3. Aug 27, 2019 at 4:58 PM
    #43
    Pdugan6
    Patrick
    Solid stock to pad the links off the frame. I think this will help keep the ride height lower.
    B18AC951-3B0B-4047-A418-EE950619F206.jpg 18A07A90-49FB-4CFF-B28F-8915C873FE82.jpg
  4. Aug 27, 2019 at 9:36 PM
    #44
    Pdugan6
    Patrick
    Lower links and brackets are on. Spotted the upper link bracket and it looks like it’s going to clear the frame and motor mount.
    Thinking elixir
  5. Aug 29, 2019 at 9:53 AM
    #45
    Pdugan6
    Patrick
    All links and brackets are in place. I’m working on full bump. I am taking off the passenger side header to make a cut on the neck above the cat to bend it away from the upper link. I need to cut the flange off and rotate it 90 degrees on the lower side of the cat. That will clearance everything and then I can focus on my panhard bar. It will need a bend around the housing to align properly with the drag link.
    I cut my links all the same at 40” center eye to eye of heim. Center line of my lower link mounts are 5” past the weld line in the frame. I’ll take more pics later.
    E8553848-D81D-4D32-BC51-D0A696082D7A.jpg DBA2350F-60D5-4A17-9DDD-CDAE0530584A.jpg B7E6CBCA-59BF-4F54-BC60-147753FAF67F.jpg
  6. Aug 30, 2019 at 3:27 PM
    #46
    Pdugan6
    Patrick
    Everything is going to clear. I took the passenger side header out to modify it a bit for clearance on the upper link. I need to make a new panhard link with a bend around the housing.
    9E660954-1FA2-4D56-8638-D16FD43C4D90.jpg 89601B0A-6731-424F-A73E-B7724D7DDECD.jpg 40A226A9-F241-473C-AF7A-46C1A10E072D.jpg AEC1ACA4-4F14-420C-BA31-F71E3E0F0288.jpg
  7. Aug 31, 2019 at 9:36 PM
    #47
    Pdugan6
    Patrick
    Cut,bent, spun the flange and welded the header so it would clear the upper link.
    CB198FB6-493C-4103-B06A-544F7F00AD4E.jpg C037E2E7-6419-4E3D-B1C8-5C26C522E1DA.jpg A22BDDDA-97E7-4521-AFFD-604ADB06B5A1.jpg 7231459E-F7A2-42B4-A7F8-AFFC03E2BDFA.jpg
    Before the modification.
    Ritchie and hoverlover like this.
  8. Sep 3, 2019 at 9:22 AM
    #48
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    Took a leaf out of your book and modified my exhaust on mine as well. Worked out great. Glad you posted pics I appreciate that.
    ToyotaRoamer86 and Pdugan6[OP] like this.
  9. Sep 3, 2019 at 9:47 AM
    #49
    Pdugan6
    Patrick
    Nice. It definitely gives AAE113EC-5EDB-4EC1-80A5-FFB65D184B3B.jpg E7F8BFDB-B4C0-4DD1-9C63-024C22BC81E0.jpg 7ED10D09-528C-483A-BC4A-5C889E08292F.jpg more room for max stuffage.
    i also had to modify the bracket to get it back in place. My flange studs are fully fucked though... I tried to put the nuts back on and it shredded the studs. Always something.
  10. Sep 3, 2019 at 9:52 AM
    #50
    Pdugan6
    Patrick
    D7C715B1-B805-4AC4-83CD-4DC659A37DD0.jpg DFFFC2E7-D961-424F-85C3-41A1CD8E800C.jpg 0BDDCB84-563D-4AB5-AA2D-7363BAE548A1.jpg
  11. Sep 3, 2019 at 3:19 PM
    #51
    Pdugan6
    Patrick
    Ordered sky off-road chromolly straight pitman arm. I need to get the steering shaft from the steering box to steering wheel. I will need to hole saw and sleeve the Barnes shock tower to clear room for the steering shaft so I can’t weld on the towers yet. I am Waiting for shocks also and Need to make a new panhard link. I feel I have been making decent progress but it seems a little snowbally right now too. Lots of loose ends. Most important right now is to get these steering issues dealt with and panhard and then things will get to the next stage.
  12. Sep 3, 2019 at 3:59 PM
    #52
    Pdugan6
    Patrick
    The master cylinder or brake solenoid(whatever the fuck it’s called) on Passenger side needs to at least temporarily be moved to cut for the shock tower. I used a step drill bit to drill out the spot welds on the bracket to remount afterwards.
    8907C80B-8028-4B6E-AF4C-6C7ABB7207CA.jpg 3F1103EC-4185-43CF-93F8-39A600FDA784.jpg 24C832B5-617E-444C-B74C-EA5E48258000.jpg
  13. Sep 4, 2019 at 2:20 PM
    #53
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    That's the ABS module.
    Pdugan6[QUOTED][OP] likes this.
  14. Sep 10, 2019 at 4:10 PM
    #54
    Pdugan6
    Patrick
    I was trying to figure out my towers if I was going to buy different ones but I decided to weld onto the Barnes towers to get the correct eye to eye measurements at full bump. 24.5” for king 14” Coilovers
    922E03E9-1C67-4968-8B1F-0E1AB57EA908.jpg 94536D39-AAE2-4984-B93F-267F1101B6AA.jpg 09242B5F-5796-4707-9698-9DADEE14799E.jpg
  15. Sep 10, 2019 at 8:38 PM
    #55
    Pdugan6
    Patrick
  16. Sep 10, 2019 at 8:42 PM
    #56
    Pdugan6
    Patrick
  17. Sep 14, 2019 at 6:22 PM
    #57
    Pdugan6
    Patrick
    Shocks came along with pitman arm and tcase crossmember
  18. Sep 15, 2019 at 7:22 PM
    #58
    Pdugan6
    Patrick
  19. Sep 16, 2019 at 8:31 PM
    #59
    Pdugan6
    Patrick
  20. Sep 17, 2019 at 4:14 AM
    #60
    Pdugan6
    Patrick
    Sky’s off-road design cromoly straight pitman arm and ruff stuff 7/8” Heim
