2nd gen Tacoma 4x4 issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05TRDsportster, Apr 28, 2023.
  1. Apr 28, 2023 at 12:18 PM
    05TRDsportster
    05TRDsportster [OP] New Member
    Cam
    05 Tacoma TRD Sport
    Pioneer sound system, 33” cooper tires, fox TRD pro front shocks, ecu tune, exhaust, rock light kit, interior accent light kit, limited edition 2011 TRD fj cruiser wheels.
    Looking for some help to figure out an issue that’s happening with my 4x4. What’s happening is when the undercarriage of my truck gets wet my 4x4 electrical system completely quits. No light will flicker on the dash for 4x4 and the actuator does nothing. The only thing I found that will get me out a pinch is if I have the truck running turn the dial to the 4hi position then pull the 4x4 fuse out and plug it back in. Then the 4x4 will engage. After I leave the truck to dry out over night then everything will go back to normal.
  2. Apr 28, 2023 at 12:23 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Apr 28, 2023 at 12:25 PM
    05TRDsportster
    Cam
    05 Tacoma TRD Sport
    No water that I’ve found anywhere.
  4. Apr 28, 2023 at 12:43 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You may want to check the vent hoses on the 4wd actuators as well, if they are cracked or disconnected they will get water in them.
  5. Apr 28, 2023 at 1:07 PM
    05TRDsportster
    Cam
    05 Tacoma TRD Sport
    I just took the actuator cap off and had a look inside of it. Nothing looks out of the ordinary. No water, no rust, and no corrosion. Still had factory yellow grease in it.
