2nd gen Tacoma center carrier bearing issues
Discussion in 'New Members' started by JPxxx7, May 1, 2021.
  1. May 1, 2021 at 8:29 PM
    JPxxx7
    JPxxx7 [OP] New Member
    2007 black Tacoma DCSB trd sport
    F/R lockers 5.29’s Chevy 63 leaf springs swap Bilstein 5100
    I just installed all new you joints and a new center carrier bearing that didn’t even need to be replaced I talked it down to 134 pounds like it says to. When I took it for a test drive going no faster than 40 mph I went to check the center bearing carrier in my driveshaft was really hot and it almost look like the bearing wasn’t spinning in the driveshaft itself was spinning inside the rubber bushing I installed it at a shop with mechanics didn’t put it on in reverse didn’t over torque it I have Center carrier bearing spacers and shims under my axle to adjust the angle and still had an issue. Has this ever happened does anyone know what’s wrong thank you
    Black DOG Lila likes this.
  2. May 1, 2021 at 8:36 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Is the carrier bearing in the correct spot front-to-back? aka install the CB bolts loosely, then get the 8 flange bolts done, then torque the CB bolts. The CB is slotted for a reason.
  3. May 1, 2021 at 8:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    JPxxx7[OP] and whatstcp like this.
  4. May 1, 2021 at 9:31 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    JPxxx7[OP] and Black DOG Lila like this.
  5. May 1, 2021 at 9:36 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The carrier bearing has a front and a back IIRC did you install it backwards?
    Did you nick or ding the dust/grease deflector on the shaft and is it contacting the bearing?
    TnShooter likes this.
  6. May 2, 2021 at 3:44 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    JPxxx7[OP] likes this.
  7. May 3, 2021 at 4:49 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    JPxxx7[QUOTED][OP] likes this.
