2nd Gen Tacoma Column Auto Shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaBuzz, Aug 8, 2010.
  1. Aug 8, 2010 at 6:30 PM
    TacomaBuzz
    TacomaBuzz [OP] Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I was wondering it it is possible to take an identical 1st gen tundra Steering wheel assy with Auto Trans column steering shifter and transplant it on a Gen2 Tacoma?? I have NEVER seen this done but is it possible? I personally prefer the Automatic Shifter on the steering column.Here's the identical Gen 1 tundra steering assy;[​IMG]
  2. Aug 8, 2010 at 6:43 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    My concern is the series of cables and linkages you would have to route to the transmission tunnel.
    How is overdrive disabled on the Tundra? Do you press a button or move the column shifter to a different notch while driving?
  3. Aug 8, 2010 at 6:46 PM
    TacomaBuzz
    CT
    I think you move the column shifter, ill have to check my friends gen 1 tundra to be sure
  4. Aug 8, 2010 at 6:56 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I highly doubt it would be worth even trying. Plus you could kiss your resale good bye. You'd have to find routing for the cables, make sure they don't bind, plug up the original gated shifter hole, probably relocate the override.... sounds like more work than moving your hand down to the gated shifter over a 20 year period
  5. Aug 8, 2010 at 7:00 PM
    TacomaBuzz
    CT
    Very true, Dimensionally i don't think toyota changed much from the gen1 Tundra to the Gen2 Tacoma, almost an exact copy. Probably not worth the effort/expense to do.
