2nd Gen Tacoma Fitting 33's with 2.5" lift
Discussion in 'Wheels & Tires' started by Sve, Dec 8, 2021.
  1. Dec 8, 2021 at 3:16 PM
    Sve
    Sve [OP] New Member
    Ricky
    2011 Tacoma 2.7L RWD Prerunner
    Vehicle: 2011 Tacoma Prerunner RWD
    Setup
    With this setup on my particular vehicle, would I be able to fit 33" tires with no rubbing without performing a CMC? If it still rubbed with the wheel offset, would 1" spacers fix it or would I need to perhaps think about getting SPC UCA's and getting a shop to push my tire as far forward as possible?
    Thanks!
  2. Dec 8, 2021 at 4:51 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    Hey Ricky,
    Welcome to the forum. You'll need a 16" wheel size or larger to clear your 2011 Tacoma PreRunner brake calipers.
    In most cases, a CMC is highly recommend with a 33" tall tire size to avoid rubbing at full flex.
    Sve[OP] likes this.
  3. Dec 8, 2021 at 4:52 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Having better UCAs will only help
    Sve[OP] likes this.
  4. Dec 9, 2021 at 1:39 PM
    Sve
    Sve [OP] New Member
    Ricky
    Oh wow this didn't even cross my mind. I'm now looking at 285/75-R16 tires paired with a 16x8 wheel with a -12mm offset. I've also decided I'm probably just going to go ahead and do the CMC. It'll give me some peace of mind knowing that I won't rub at all even if I stuff my wheel. Thanks so much!
