2nd Gen Tacoma Front End Wobble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueBeast08, Jul 15, 2025.
  1. Jul 15, 2025 at 9:26 PM
    BlueBeast08
    BlueBeast08 [OP] Member
    2008 Tacoma Dbl Cab 4x4
    Hey guys, I’ve been trying to diagnose a front end wobble noise in my 2nd gen for the better part of a year and a half now and finally made an account to see what you guys think as I am stumped at this point. The wobble is rotationally rhythmic and gives a faint vibration felt in the floor board and steering wheel. The wobble can be felt and heard from 1mph to 35mph and is more prominent when turning left at lower speeds. I did notice that when im in traffic and going slow (1-10mph) I can visibly see the front drivers side slightly bounce up and down every 2-3 seconds. At this point the entire front suspension has been upgraded and replaced since the issue started happening.
    Here’s what Ive done so far:
    • Icon stage 1 suspension with 14” 600lb King springs, lift set at 2” with aal in the rear
    • Billet UCAs
    • New LCAs
    • Icon Tie Rods
    • New steering rack (old steering rack wore out)
    • Upper intermediate shaft
    • Front wheel bearings
    • New CV axles
    • Brake rotors, calipers and pads
    • End links (eventually just deleted sway bar)
    • Diff drop
    • Carrier bearing and ujoints
    • Rims and tires (Yokohama Geolander G003 285/75r17)
    • 3 alignments and wheel balancing
    There is no play in the front end that I could find when on stands. Im out of ideas so any suggestions would be greatly appreciated!
  2. Jul 16, 2025 at 4:34 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Could be front differential needle bearing. ECGS sells a replacement bushing. Lots of write ups on here describing testing method and how to install.
  3. Jul 16, 2025 at 10:39 AM
    BlueBeast08
    Sorry i forgot to add that to the list but i replaced the needle bearing with the ecgs bushing
  4. Jul 16, 2025 at 10:57 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Broken belt in a tire. Front or rear....I've seen it. Worth a look.
    isdjww, winkel and Clearwater Bill like this.
  5. Jul 16, 2025 at 11:21 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’m just curious how you drive 1mph.
    303tacoma likes this.
  6. Jul 16, 2025 at 11:36 AM
    BlueBeast08
    Tires are 3 months old, the problem started a year before the new tires, I tried rotating them to see if it made a difference but unfortunately it didnt. I may take it to a tire shop to get them checked just in case. Do you think it could be the lower intermediate shaft? Not too sure what kind of symptoms that would cause other than steering bind. Thanks for the info!
  7. Jul 16, 2025 at 11:38 AM
    BlueBeast08
    Very skillfully when bored in gridlock traffic haha
  8. Jul 16, 2025 at 12:03 PM
    That one old guy
    Chuck
    Stockish
    Wouldn't hurt to have a good shop take a look, I've seen newer tire's belts fail too. All it takes is the right pot-hole or curb. Intermediate shaft is possibility as you suggest. These things can be sometimes compounded when a lift and bigger tires comes into the game. Good luck & report your findings please. :thumbsup:
  9. Jul 16, 2025 at 12:40 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Mount a camera and have it record the drivers wheel and suspension and go for a spin
    gotoman1969 likes this.
  10. Jul 16, 2025 at 1:55 PM
    gotoman1969
    So on a serious note. If you can feel at that slow a speed, something has to be loose, bent or obvious it would seem. If a tire had a really bad broken belt and you felt at that low a speed it would be horrible at high speeds. When you say wobble it feels like the truck has a slight rock n roll as you drive? Bent wheel, bent hub? I like the idea @knottyrope mentioned filming while driving up and down your street.
  11. Jul 16, 2025 at 2:09 PM
    JAGCanada
    Canada
    Looks like you've replaced everything. I've read about bent spindles before... how long had you had the truck before it started to make noise? I'm ssuming you've done the basic test like lift the truck, spin wheels, rock wheels, etc.
    That one old guy likes this.
  12. Jul 16, 2025 at 3:44 PM
    ryoung40911
    ryoung40911 Reggie Cab Connoisseur
    Rich
    NH, USA
    Barcelona red 4x4 regular cab 2014
    OEM FJ TRD pro wheels F/R ECGS 4.88 differentials with truetrac out back Bilstein 6112/5160 shocks Icon RXTs stage 0 (3rd leaf removed from stage 1) Icon tubular Delta UCAs Durobumps with Ubolt flip kit Rear X-runner sway bar, no front bar Reinforced LCA cam tabs with locking hardware 2014 steering wheel with radio controls, lights, and cruise control Alphasucks headlights Engine splash guards I made from a template on TW Other random stuff like ac knobs and a shorty antenna
    In an auto, by taking your foot off the gas lol
  13. Jul 16, 2025 at 5:14 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    At this point, I'd put it up on jack stands, put it in gear and let it roll in the air. See if you can see any bounce coming from that wheel or corner of the truck.
  14. Jul 16, 2025 at 5:17 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    When I lifted my truck I had the same issue and I added some 5° shims between the leaf springs and the axle. It cured the vibrations.
  15. Jul 17, 2025 at 12:00 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Front cab mount bushing/radiator support bushing.
    Replace all 6 cab mounts with poly from energy suspension.
    You owe me a pizza :D
  16. Jul 17, 2025 at 12:20 AM
    BlueBeast08
    Yeah a slight rock and roll would be the best way to put it, at high speeds theres no issues, no play or vibrations, no clunking and it does great with pot holes and speed bumps. I did check everything again today for any sort of play to no avail. I made an appointment at a local tire shop to get an inspection and possibly another wheel balance. So far the tires haven’t shown any sign of uneven wear. I like the camera idea though! I’ll most likely put my GoPro under there this weekend and see if I notice and movement. Thanks for the recommendations!
  17. Jul 17, 2025 at 12:33 AM
    BlueBeast08
    I was wondering about bent spindles, I have a spare set laying around that I was going to get gusseted, I’ll try throwing them on sometime soon. I’ve lifted the truck and tested for play and its all super solid. I did notice that when I lift truck from the LCAs, the drivers side seems to compress more than the passenger side. Not sure if thats normal or not, I figured its from Taco lean. What do you guys think?
  18. Jul 17, 2025 at 12:35 AM
    BlueBeast08
    Im definitely ordering that soon to get it out of the way, even if it doesn’t fix it ill have new bushings. But if it does fix it you’re getting pizza!
    will.i.was[QUOTED] likes this.
  19. Jul 17, 2025 at 3:58 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Here's a thought. Raise up the truck and rotate the front drivesshaft and tires. Feel for play from a broken tooth on a gear. Some of your symptoms sound the same as a friend had when we were out in Moab. He had 2 broken teeth on a spider gear, but in the rear diff.
  20. Jul 18, 2025 at 10:34 PM
    BlueBeast08
    I’ll check that out this weekend! Might be time for a regear soon.
    Thanks!
