2nd gen Tacoma fuel pump
Discussion in 'Technical Chat' started by Kevinkiger16, Nov 14, 2019.
  1. Nov 14, 2019 at 7:00 PM
    Kevinkiger16
    Kevinkiger16 [OP] Active Member
    Kevin
    2007 tacoma 2.7 manual
    Anyone had the fuel pump pick up tube come off?i run outta gas at a quarter tank. Wondering if the pick up tube just fell off if so can I put it back on or is it hard molded on??
  2. Nov 17, 2019 at 1:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Anything is possible I never heard of this ever happening.
    Are you sure you don`t have a sending unit problem?
  3. Dec 18, 2019 at 7:40 AM
    Kevinkiger16
    Kevin
    I have no idea all I know is when I have a quarter tank of gas my truck will turn off. Should I just replace the fuel pump or is there another solve for this problem
  4. Dec 18, 2019 at 7:57 AM
    96carboard
    96carboard Well-Known Member
    I think you gotta open it up to find out what's going on there.
    Or live with it.
    Those are your only 2 options.
  5. Dec 18, 2019 at 8:56 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    It just may be that the sending unit or gauge is faulty. When you “run outta gas” how many gallons does it take to fill the tank? Your tank holds either 21 or 22 gallons. If you still have a quarter tank then it should only take about 15 gallons give or take a gallon or two to fill it. If it’s truly empty then it will take around 21 gallons or so.
