2nd Gen Tacoma Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ctheulen, May 3, 2022.
  1. May 4, 2022 at 1:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the rack bolts and bushings?
    reallifedog likes this.
  2. May 4, 2022 at 1:43 PM
    ctheulen
    ctheulen [OP] Alaskan Assassin
    Glenwood Springs, CO
    2005 Tacoma SR5 4x4 DCLB
    3 inch lift Toytec Ultimate Coilovers Deaver Stage 3 leaf pack Camper shell w/ Prinsu Rack and RTT Maxxis Razr MT 285/75/16
    Good information to learn though!
    Steves104x4 likes this.
  3. May 4, 2022 at 1:43 PM
    ctheulen
    I haven’t yet. That’s next
    TnShooter[QUOTED] likes this.
  4. May 4, 2022 at 2:22 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Use some silicone grease spray on your rad/body mounts and listen then. Could even go Rad then body mounts for an easier diagnosis. Make sure everything you've replaced is properly torqued...
    I had a broken rad-mount on the passenger side that I was convinced must be a suspension component causing all the creaking and clunking. The poly-bushings noted on the forum are a good replacement.
  5. May 4, 2022 at 3:32 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Make sure it is in the front and not the rear... Leaf springs or brake noise could be fooling your ears. I had my left rear drum brake fail and I was sure it was the front disc locking up... until brake fluid began to flow out of the rear, later that day!
  6. May 4, 2022 at 4:30 PM
    ctheulen
    That's alright, great to know about for the future!
  7. May 4, 2022 at 4:31 PM
    ctheulen
    Great point. Although the noise happens simultaneously as the front goes over a bump.
  8. May 4, 2022 at 4:32 PM
    ctheulen
    I inspected/ used a pry bar to see if I had any play in those and all checked out. But I'll hit them with some silicone and see if there's any change.
  9. May 4, 2022 at 4:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Placed my open palm on the driver fender above the wheel opening. Pushed forward then pulled back and wouldn’t you know it… that was the clunk I was hearing. The fender was loose. I tightened the bolts a smidge and its been silent for the last 10 years. Good luck!
  10. May 4, 2022 at 4:51 PM
    ctheulen
    Haha, I think I've read somewhere else on TW about you doing that. I have a feeling it will be something very similar.... took this truck elk hunting last fall and on the last day, it was a muddy mess. I'm pretty sure that's when it happened.
    Steves104x4[QUOTED] likes this.
  11. May 4, 2022 at 4:52 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I keep repeating myself. Internet dimentia. Dementia :oops: Oe, what was I saying?
    ctheulen[OP] likes this.
  12. May 4, 2022 at 4:55 PM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    I finally was able to track down a clunk in my truck a week ago that was a sway bar bushing. Point being, have someone aggressively rock your truck side to side. By doing this I was able to watch all the suspension components and poke my head around to hear anything.
    Best of luck
  13. May 4, 2022 at 4:59 PM
    ctheulen
    Sway bar bushings have been replaced and hit with some energy suspension lube. Even did a temp sway bar delete on that old sucker. Noise still squealed like a pig...
  14. May 5, 2022 at 6:18 AM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Same issue here. Have you checked your front differential support arm bushings ? Mine look bad. I will be changing those next.
  15. May 5, 2022 at 8:02 AM
    #35
    ctheulen
    I need to check those. Needing to check the torque on the bolts too.
  16. May 5, 2022 at 12:18 PM
    #36
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This is more telling … did the mechanic remove engine shield/guard and check all components within arms reach? Do you feel clunking in steering wheel?
  17. May 9, 2022 at 9:09 AM
    #37
    ctheulen
    Well, went wheeling in Moab this weekend.. and the noise is gone. Must've been something lodged where it shouldn't have been!
