2nd Gen Tacoma Propeller Shaft U Joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chuckle Norris, Jan 20, 2023.
  1. Jan 20, 2023 at 3:28 PM
    Chuckle Norris
    Chuckle Norris [OP] New Member
    2014 Tacoma 4WD
    So I have been reading a lot on forums about U Joints but have not found a correct spec for the (2) U joints for the front propeller shaft on the Double Cab 4WD model. The common joints offered by a million auto part stores are for the rear (2) piece driveshaft that are about 3.62" cap to cap. The front ones are smaller - has anybody replaced these recently and what is the model number and auto store you got them from. The cheapest I can find from a dealer or OEM store on line is upwards of 60 bucks. Lots of links on here to Spicer joint websites but they are not the correct joint for the front.
    Bocotacointhewild likes this.
  2. Jan 20, 2023 at 3:35 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    AllTacosFloat, TnShooter and nd4spdbh like this.
  3. Jan 21, 2023 at 4:09 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Rockauto will save you alot of money.
    BusyBee212 and steelcity2 like this.
  4. Jan 21, 2023 at 12:11 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Do yours squeak or have play? I still have oem at the front with 200K+ and they are holding up well. Even though I off-road and use 4x when I need it, the front joints just don't nearly see the same amount of stress as the rears. I would leave them alone unless you happen to take apart the front diff to change gears or something, or they are actually damaged.
    SR-71A likes this.
  5. Jan 21, 2023 at 7:59 PM
    philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    - philo
    Nashville, TN
    2010 Gray Tacoma TRD
    Tom Woods Custom Driveshaft
    I've only ever been able to find the rear u joints on Rockauto
  6. Jan 22, 2023 at 1:09 PM
    fixnfly
    S.W.PA
    They have the fronts now.
