2nd gen Tacoma shifting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheRedTaco03, Jul 21, 2022.
  1. Jul 21, 2022 at 3:41 PM
    TheRedTaco03
    TheRedTaco03 [OP] Member
    Alex
    2014 Red 4x4 V6 Tacoma Access Cab
    None yet
    Hello everybody. I have a 2014 Tacoma with the 4.0 V6 4x4. I recently installed a pedal commander and a k&n intake. After driving for 100 miles or so I didn't like the way the truck drove. I took the pedal commander off first. Nothing changed. Then I took the intake off and put the factory one on but still something seems off. The shifting seems weird. The truck shifting seems a little off, I hope I didn't hurt anything. I've driven the truck for a couple days now but nothing seems better. Also it seems like when I press the gas pedal I get a good amount of feedback, rpms instantly drop before shooting back up. Truck has 19,000 original miles. Any suggestions or ideas as to what I could be experiencing. Any help is much appreciated thank you all in advance
  2. Jul 21, 2022 at 3:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You may need to do a battery disconnect to reset any learned values that could have gotten out of whack with the aftermarket stuff installed.
  3. Jul 21, 2022 at 5:09 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    ^Disconnect the battery and leave the OEM intake on. Pedal commander should be ok.
  4. Jul 21, 2022 at 5:30 PM
    TheRedTaco03
    Alex
    None yet
    Thank you guys for your reply. I did disconnect the battery to try to reset the ecu. Also put both terminals together. Is that the right measure to take to reset it? Or is it different with newer vehicles? Also how many miles will it take for it to go back to normal its been over 100
  5. Jul 21, 2022 at 5:36 PM
    TheRedTaco03
    Alex
    None yet
    The pedal commander can't hurt my truck right? I only had it on for 3 days and then took it off but I'll be honestly I sorta beat on my truck within those 3 days LOL I kinda regret it but thought it would be fine
  6. Jul 21, 2022 at 6:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Disconnecting the battery for a few min is sufficent to clear most of the adaptives, it should have relearned most things after 100mi.
    Next thing I'd reccomend since you say your having shifting issues is to check your transmission fluid level, see the thread below for the proper procedure.
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    It shouldn't, all it does is intercept the signal from the acelerator pedal position sensor and modifies it so that the PCM sees more or less pedal input (depending on the setting) than the actual position of the pedal.
  7. Jul 21, 2022 at 7:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When you installed the pedal commander, was the battery disconnected.
    I ask because, like others said, it clears learned data. So it needs to relearn.
    My 07’ doesn’t seem have a drastic “relearn” process like the 13’ model truck I put a battery in.
    I think the later model trucks don’t tolerate “changes” as well. It takes them time to learn.
  8. Jul 22, 2022 at 8:13 AM
    TheRedTaco03
    Alex
    None yet
    ah ok thank you for that insight. No the battery wasn't disconnected when I installed or removed it. Hopefully it'll relearn everything soon but there's no way that the pedal commander could've hurt it right? Sorry for being paranoid I just bought the truck a month ago
  9. Jul 22, 2022 at 9:19 AM
    TnShooter
    Deogee
    STOCK
    No, the pedal commander didn’t hurt it.
    If it did, you have a check engine light or something.
    I think you need to drive it for a week and come back and tell us how it runs. I bet it will be just fine.
    It probably in your head man. I get that way sometimes myself. You’ll be fine.
  10. Jul 22, 2022 at 10:08 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I don't think so, you would have codes if there was a problem with the throttle system.
    I would still reccomend checking the transmission fluid, it's good practice to do anyway since there's no dipstick to check it.
    TnShooter likes this.
  11. Jul 22, 2022 at 11:06 AM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    I had a PC for about a year and really liked it, but then I started getting P2121 code intermittently (problem with the accelerator pedal position, or APP, sensor). I turned off the PC, but still would get the error. I finally removed it and haven't had a problem since (12 mos.)
