2nd gen tacoma side marker issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghosted808, Aug 16, 2023.
  1. Aug 16, 2023 at 2:04 PM
    Ghosted808
    Ghosted808 [OP] Member
    05 Toyota Tacoma
    Does anyone else have this problem with their 2nd gen tacoma? I just installed new retrofit headlights 2 weeks ago and the side marker lights used to come on by itself with out the low beams on. But now when i turn my light cluster to just the side marker lights… my low beams come on with them when it’s not supposed to. I have checked all connections to my new lights,power an ground has been checked. But still can’t figure what would be the issue. If anyone has insight or solutions it would be appreciated. I even checked the 4 10amp fuses for the headlights an they all look good. Could it be my head light relay or is it something else?
  2. Aug 16, 2023 at 8:32 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Sounds like a wiring issue inside the retrofits. Did you build them? If so, time to do some sleuthing. If another vendor/seller built them maybe ask them, they may have more details on specifics.
    Ghosted808[OP] likes this.
  3. Aug 16, 2023 at 10:24 PM
    Ghosted808
    05 Toyota Tacoma
    That’s what i was kind of pinpointing it to or the controller itself, the retro lights are from teq customs. So i will have to email them tomorrow an ask what could be the issue an if they can send a controller to test. I checked everything over again, my headlight switch, fuse box under the dash, an even switched my headlight relay with a new one to no luck. Mahalos for your insight man will keep updating til i get it fixed! I’m just surprised no one else had this issue, or posted about it.
  4. Aug 18, 2023 at 1:14 PM
    Ghosted808
    05 Toyota Tacoma
    So i ruled out that it wasn’t my headlight wiring it self or the controller. Since i checked all my fuses an relays, last thing it could be is my headlight switch. Unless theirs some other fuse or relay that i haven’t checked. Time to go buy a headlight switch from oriellys an change it to see if that’s the issue..
  5. Aug 18, 2023 at 1:18 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if you connect the original lights back up does it do it?
  6. Aug 19, 2023 at 10:48 PM
    Ghosted808
    05 Toyota Tacoma
    If i hook my bone stock headlights back up and remove my retro’s completely, it still does the same thing. My low beams will still come on with my side marker lights, when it’s supposed to be side marker only mode. I have checked my tail fuse under the dash, checked my relay for headlights an fuses… only thing left that could be the problem is my headlight switch, or actual fuse box under the dash. But i’m not 100% certain..if anyone has else knows what it could be, i’m all ears
  7. Sep 17, 2023 at 6:28 PM
    Ghosted808
    05 Toyota Tacoma
    Just got enough time to install my new headlight switch but still no luck in fixing the issue. I’m at a stale mate to getting my side marker lights to come back on by it self ‍
