2nd gen Tacoma starting issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by O17297, Sep 3, 2024.
  1. Sep 3, 2024 at 11:25 AM
    O17297
    O17297 [OP] Member
    Edi
    2009 Tacoma
    200,000 miles 2WD
    Hello y’all ! I just recently have been having starting issue with my Tacoma , I just recently replaced my starter ( 2 weeks ago ), alternator ( 4 days ago ) , and battery ( last month ) . Wondering what’s the problem here now ?
    here’s how it sounds like !!
    https://youtube.com/shorts/VOgouzzQlec?si=BoeUd_6stx0jfZBa
  2. Sep 3, 2024 at 11:37 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Sounds like a starter bendix issue where it's not engaging with the flywheel. OR, you have a bad connection somewhere that is limiting the draw the starter needs. I'd check for corrosion on both ends of the cables and all grounds. If you see green traveling up under the wire insulation or at a crimp, replace the cable.
    O17297[OP] and Chuy like this.
  3. Sep 3, 2024 at 11:44 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Was that sound present from the first time starting the truck? What brand starter? What brand, group type, and CCA rating of the battery?
    O17297[OP] likes this.
  4. Sep 3, 2024 at 12:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree that it sounds like the starter bendix is not properly engaging with the flywheel ring gear. I'd pull the starter and give it a look before having to replace a chewed up flywheel.
    O17297[OP] and gotoman1969 like this.
  5. Sep 9, 2024 at 6:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hey any updates on a solution?
  6. Sep 10, 2024 at 10:03 AM
    O17297
    O17297 [OP] Member
    Edi
    Turns out it was my battery , looking to switch it out for a “interstate” battery this Thursday !
  7. Sep 10, 2024 at 10:33 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well a month old battery was defective. Good you found it.
