2nd Gen Tacoma Tire size question (315 75R16
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ronjohn9631, Aug 23, 2019.
  1. Aug 23, 2019 at 4:43 PM
    ronjohn9631
    ronjohn9631 [OP] Member
    Been following this forum for a long time and it has helped me out tons over the past few yrs but I have a question I just can't seem to find the answer, I guess I'm going to post my first question. I have a 2012 Double Cab with 3" lift, total chaos uca currently running a set of Discoverer LT305/70T16 mounted on 16x8 wheels 4.5" BS with zero contact or rubbing. I already trimmed 3" off fender Wells, Cab Mount Chop, seem is already hammered body seam etc. My question is t for guys(anyone else who may know) running LT315/75R16 or 35's Will these tires clear the UCA with out rubbing with 4.5BS and if not what do you guys suggest I really don't want my tires sticking out much more then where they are now.... Thx in advance for your guys help...
  2. Aug 23, 2019 at 5:21 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    doubt you'll have issues. depends on the tire actual size when mounted up though. I have 36x12.5 on 4" BS and it clears the total chaos UCA just fine.
  3. Aug 25, 2019 at 3:07 AM
    ronjohn9631
    Thx for the info,
  4. Aug 27, 2019 at 6:09 AM
    ronjohn9631
    Is anyone else running 315/75r16's with 4.5"bs without spacer without any UCA contact or frame rub at full lock.
