2nd Gen Tacoma Travel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bubbarr, Nov 24, 2011.
  1. Nov 24, 2011 at 4:41 PM
    Bubbarr
    Bubbarr [OP] Monkey Sweat
    Duane
    SD
    TRD Off-Road 4X4
    DynoLock Auto tailgate lock, 16" Konig Counter steer Off roads, 265/75/16 Goodyear Wrangler Duratracs, 2.5 King front and rear with remote reservoir, Built Right UCA, Deaver 3 pack, SD Truck Shop Custom Sliders.
    Does anyone know how much travel a stock 2009 Tacoma TRD Off Road has both front and rear? Tried looking it up but couldnt find it
  2. Nov 24, 2011 at 4:47 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I believe 7" total up front ... and the rear is close to the same but not sure on the exact number
  3. Nov 24, 2011 at 4:51 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Interesting topic. Is this typical for most production 4x4 trucks? What are typical numbers for mid and long travel Taco setups?
  4. Nov 24, 2011 at 7:40 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    I am asking this because my friend just bought a new Ford Raptor. They are sporting 11.2" of travel in the front and 12.1" of travel in the rear. Just wanted to know what we have. Trying to figure out what I have now that I have my new suspension as well. I want to know if I can hang with the Raptor.
  5. Nov 24, 2011 at 7:46 PM
    MonkeyProof
    SoCal- SGV
    No way you'll be able to hang if you have stock suspension. Not only does the raptor have a decent amount of wheel travel...the fox shocks that are on the raptor are specially tuned just for that truck and they are internally bypassed.
  6. Nov 24, 2011 at 7:50 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Not for what it's designed for, which would be desert running. But then, get on some tight trails and watch him not be able to make turns.
    Modified suspension setups on Tacomas allow for raptor-like numbers. But it'll cost a bit of coin.
  7. Nov 24, 2011 at 7:57 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    My truck is not stock. I have king suspension all around, UCAs and deaver leaf springs.
  8. Nov 24, 2011 at 8:00 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    :laughing:
  9. Nov 24, 2011 at 8:05 PM
    BMOC
    Paden
    Phoenix, AZ
    yeah, you're right. it was just funny that you shot him down so quick :rofl:
  10. Nov 24, 2011 at 8:11 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Do the Icon + uniballs allow for more uptravel if you removed the factory bumpstop?
  11. Nov 25, 2011 at 1:13 AM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    So do the Icons give more travel than the Kings?
  12. Nov 25, 2011 at 1:24 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Icon told me 10" if used with their uca and camburg quoted me 10.5" with theirs. I'm pretty sure I've ran across a few members with 9'-10" range with a uniball and ext travel! But I'm running toytec so I wouldn't know! Id say with some ext travel shocks, uniballs, jounce shocks/upgraded bump stops, decent rear springs and enough fender clearance you would keep up. Still cheaper than a raptor and could wheel plenty of other places the raptor couldn't!
    OP - Have you wheeled with him and tried to keep up? Just curious! Your prob in decent shape but would want to build the rear first.......full deaver pack or defined SUA with some 10" travel shocks to start with!
  13. Nov 25, 2011 at 11:35 AM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    I have not wheeled with him yet. He just got the truck and has yet to try it out. Your probably all right though. Been watching some Raptor videos and that thing can take some mean jumps stock. Dont think I can do that with my current build. Need to put more into my truck. At least it feels better than it used to with what I have now.
  14. Nov 25, 2011 at 11:59 AM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    I have the extended travel ones.
  15. Nov 25, 2011 at 12:02 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    then why did you ask about stock travel numbers?
  16. Nov 25, 2011 at 12:04 PM
    PLC721
    Patrick
    Chandler, Az
    you probably have 9-10" of travel if you have ext travel with unibals
  17. Nov 25, 2011 at 12:46 PM
    Bubbarr
    Duane
    SD
    TRD Off-Road 4X4
    I asked about stock because I wanted to know the stock numbers. I would then assume that I have a bit more than stock. I didnt want to ask "Hey does anyone know what my suspension travel is?"
  18. Nov 25, 2011 at 7:41 PM
    KenLyns
    Belly of the Beast
    A stock Raptor has its limits. The rear suspension has spring-over-axle and a lift block:
    The rear bumpstop is mounted on the frame, not on the axle, which means there's a hole in the frame where it's weakest. If your friend actually attempts those jumps shown in Ford's promotional videos, he may bend his frame. The more serious Raptor users weld on frame reinforce plates and run hydraulic bumpstops.
  19. Nov 25, 2011 at 7:53 PM
    MonkeyProof
    SoCal- SGV
    all F-150 have that block, not really a "lift block" per say as it incorporates into a striking pad for the bump stop since Ford uses "out board" placed shocks.
  20. Nov 25, 2011 at 8:09 PM
    PLC721
    Patrick
    Chandler, Az
    And it is easily gusseted
