2nd Gen Tacoma upstream O2 sensor replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by squamish VFR, May 29, 2019.
  1. May 29, 2019 at 1:31 PM
    squamish VFR
    squamish VFR [OP] Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs, FJ manual TC conversion, basket winch front and rear, hidden hitch in the front behind licence plate. Spyder headlights, tailgate seals.
    Hey there hive mind.
    At 210,000K I was thinking of spinning a couple new up stream Denso O2 sensors into my '06. Had a look at it and it seems like a bit of a bitch to get in there. Any tips and tricks to getting up there to spin them out? Additionally neither Napa or Lordco seem to have a Denso number for the upstream sensor and they are only offering me Bosch sensors, is it because they are not available or because I'm in Canada?
    b_r_o likes this.
  2. May 29, 2019 at 1:52 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Are they throwing a code? If not, I'd say don't worry about it. I've got over 482km, 300k miles, on mine. :thumbsup:
    b_r_o likes this.
  3. May 29, 2019 at 1:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If they were causing a problem they would be coding.
    if you're wondering about fuel mileage or the performance of the EFI system get a little code reader that can let you watch short/long term fuel trims
    Larzzzz likes this.
  4. Jun 2, 2019 at 3:08 PM
    squamish VFR
    No codes at this point but it often but not always has a low guttural growl when releasing the last bit of the clutch that sounds to my ear to be spark knock. I had a '90SR5 3.0 that never threw a code but I replaced the O2 sensor and it brightened right up the way the engine ran and stopped the uphill pinging.
  5. Jun 3, 2019 at 4:43 PM
    jacobgosaints
    jacobgosaints New Member
    jacob
    1997 Black Tacoma 2.7L 4x4 Extended Cab
    I have a 1997 4x4 tacoma with a 2.7L engine and I'm wondering how hard would it be to replace the O2 sensors ?
