2nd Gen Tacoma V8- LQ4/4L80E Swap plus smattering of extras
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Camazon, Dec 6, 2022.
  1. Dec 8, 2022 at 10:58 AM
    Camazon
    Camazon [OP] Well-Known Member
    Cam
    Vancouver,BC
    06 Tacoma TRD Off Road DCSB
    I’ve been asking many a question to Chris and it’s been super helpful!
  2. Dec 9, 2022 at 6:33 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    Being an 01 his didn't have DOD.
    ColoradoTJ likes this.
  3. Dec 9, 2022 at 8:53 AM
    Reddirtnaps
    Reddirtnaps Well-Known Member
    Oklahoma
    2019 DCSB 99 UZJ100
    Shouldn’t. Afm came out in the 07s
    Hayden334[QUOTED] likes this.
  4. Dec 9, 2022 at 10:52 AM
    Camazon
    Cam
    Vancouver,BC
    What’s DOD? And AFM?
  5. Dec 9, 2022 at 10:58 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Displacement On Demand and Active Fuel Management, it's Chrysler and Gm's cylinder deactivation (introduced around the 07 MY).
    The idea is the engine can shut down half it's cylinders during low load cruising to save fuel but in reality the fuel saving are minimal and the lifters on the DOD/AFM cylinders are a source of constant problems.
  6. Dec 9, 2022 at 11:04 AM
    Camazon
    Cam
    Vancouver,BC
    Thanks for the info! Similar concept to what Ford have.
  7. Dec 9, 2022 at 11:32 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ford didn't add it until around 2020 and it's only on the 5.0L as far as I know so the jury is still out on how reliable theirs will be.
    Hayden334 likes this.
  8. Dec 9, 2022 at 11:42 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Comment you quoted was not directed at the OP
  9. Dec 9, 2022 at 11:46 AM
    Dawdaw808
    Dawdaw808 Well-Known Member
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
    Same
  10. Dec 9, 2022 at 12:00 PM
    Hayden334
    Hayden
    Cullman, Alabama
    Yeah I can see that
  11. Dec 9, 2022 at 12:04 PM
    Hayden334
    Hayden
    Cullman, Alabama
    I will say this though. They seem to have it worked out on the LT motors. We rented a 2020 Suburban to drive to San Antonio a couple years back. With 5 adults, a baby and enough luggage for everyone for a week. We got 26 MPG at one point and averaged 22 MPG driving across Texas. It blew my mind.
  12. Dec 9, 2022 at 12:10 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea if only they could make an AFM lifter that didn't fly apart or get stuck:rofl:
  13. Dec 9, 2022 at 12:13 PM
    Hayden334
    Hayden
    Cullman, Alabama
    I know right, They did make some changes for 2016 MY that was supposed to correct or make it less prone. My buddies wife had a 2015 Tahoe that ate a lifter at like 100K and we swapped in a junkyard motor out of a wrecked 2016 with 50K on it. so far so good.
  14. Dec 9, 2022 at 12:19 PM
    Reddirtnaps
    Oklahoma
    2019 DCSB 99 UZJ100
    I had an 08 I put 260k on that never dropped a lifter or had any trans issues. Did have the dreaded o ring failure though.
  15. Dec 9, 2022 at 12:42 PM
    #35
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I've seen GM techs doing 21s with only a few k miles on them so I would say that no they aren't fixed. Not to say that every one will fail but they do have a high failure rate and typically give no warning before they go. Same thing with the GM 6L80/90 transmission, when they are done they just stop moving without warning (typically around the 100-150k mark from what we see).
  16. Dec 9, 2022 at 12:56 PM
    #36
    TireFire
    Olympic Peninsula
    No doubt!! It’s awesome when you can reap the benefits with no worries about failures/repairs when those are someone else’s problems.
    I also used to get up to 29mpg in my Tahoe when just cruising on flat highways mostly in V4 mode. Then at some point I started getting misfires…
    On the latest engines GM now uses “dynamic fuel management” which allows way more firing combinations than just V8, V6, or V4. Now the lifter failures are even worse and frequently happen on new vehicles even before the first oil change.
    Thankfully these engines are easy to work on with gobs of aftermarket support, and you can rebuild your top end with non DOD parts. The warranty fix is BS because GM will only replace a faulty lifter with the same part number so it can just fail again…
    Hayden334[QUOTED] and Dm93 like this.
  17. Dec 9, 2022 at 1:35 PM
    #37
    Camazon
    Cam
    Vancouver,BC
    That’s all good info to know.
  18. Dec 9, 2022 at 7:01 PM
    #38
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Yeah do not get an afm/dod engine….unless you’ve seen it run and it’s a steal…than just swap the lifters and put a mild cam in and ur good.
  19. Dec 9, 2022 at 7:53 PM
    #39
    Camazon
    Cam
    Vancouver,BC
    Got enough on my plate to be looking for another setup haha
  20. Dec 9, 2022 at 8:24 PM
    #40
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    true…true… yeah I remember figuring out all the logistics that first time was a bit of a nightmare. Now changing things later is easy for me since I can now see how it’s laid out and figure out how I want to make it better.
    SR-71A likes this.
