2nd Gen Tacoma Water Pump.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kilroy2963, Dec 23, 2022.
  1. Dec 26, 2022 at 4:06 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I think the only times I have seen posts of people who needed to change the original water pump are from those that live in the rust belt or those who live near salt water. Those that don't are the only ones that haven't changed it.
  2. Dec 26, 2022 at 7:28 PM
    Japoison
    Japoison Member
    2008 Toyota Tacoma TRD Sport 4x4
    OME Lift
    2008 210,000 miles original water pump. I have changed the coolant 3 times and I am in my second radiator.
    GilbertOz likes this.
  3. Dec 27, 2022 at 4:42 AM
    Alealexi
    Houston, TX
    What happened to your first? I still have original radiator.
  4. Mar 3, 2023 at 11:25 AM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Did any of y'all use the water pump gasket, or did you use rtv, gasket maker, or similar?
  5. Mar 3, 2023 at 11:27 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Always use the gasket if one is available, rtv is messy and looks backyard
    Dm93 likes this.
  6. Mar 3, 2023 at 11:28 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Use the gasket, no RTV needed.
    Taco 422[QUOTED] likes this.
  7. Mar 3, 2023 at 11:44 AM
    Taco 422
    USA
    I generally use yamabond on everything.
  8. Mar 3, 2023 at 12:39 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I have 155K still good - hope I'm not jinxing myself by posting this. My brother-in-law got 255K on his B 4 he had to change it.
    Just thought I'd add a reply to the OP - The Stealership is just trying to add to their bottom line as always.
  9. Mar 3, 2023 at 2:27 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Mechanics generally hate people like you.
    tacoman45 and b_r_o like this.
  10. Mar 3, 2023 at 5:27 PM
    Taco 422
    USA
    Can't argue with results
    tacoman45 likes this.
  11. Mar 3, 2023 at 7:10 PM
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Nope, Yamabond is some amazing shit.
    tacoman45 and Taco 422[QUOTED] like this.
  12. Mar 4, 2023 at 11:24 AM
    Alealexi
    Houston, TX
    Use the gasket it comes with.
  13. Mar 6, 2023 at 11:04 AM
    Taco 422
    USA
    Oh, and 2006, 26x,000 miles, original water pump. Getting changed this week.
  14. May 4, 2024 at 6:05 AM
    ebulang
    ebulang Active Member
    Manny
    Cumming, GA
    SR5
    I have a 2005 Tacoma with 355,000 miles with original water pump, thermostat, hoses, radiator, etc.
    I'm contemplating if I should replace the water pump and thermostat. So far I haven't heard any abnormal noise from the truck. Any suggestions?
    ToyoTaco25 likes this.
  15. May 4, 2024 at 7:35 AM
    #35
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I’d replace the hoses and maybe the thermostat. I’d let the rest be.
  16. May 4, 2024 at 7:48 AM
    #36
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    I recently replaced my water pump at ~180k because it was making an ungodly noise, or so I thought. No puking through the weep hole but upon removal there was a tiny bit of play in the shaft.
    Got it all back together, noise was still there. Turns out the fan clutch was entirely buggered and the vibrations were taking out the pump. Replaced that (MUCH easier job) everything was all better. Original WP was probably still okay, but glad I replaced it as I'm sure its life was significantly shortened.
  17. May 4, 2024 at 7:55 AM
    #37
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Same boat but with 286k. No noises or issues overheating. I’m just gonna let it ride for now.
  18. May 4, 2024 at 8:00 AM
    #38
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    235k on my 06 pump...still fine. Only replacing the radiator because of my wreck so....
  19. May 4, 2024 at 9:27 AM
    #39
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    220K in 2010 4Runner and still good. Thinking about just doing a radiator coolant drain and fill but now contemplating in replacing pump/thermostat and hoses just as preventative maintenance. Either that or just leaving it alone because i’ve seen what’s inside a radiator at 200K miles but that was on a Chevy.
  20. May 5, 2024 at 5:29 AM
    #40
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    2005 all original. The only thing I’ve considered is replacing the radiator, thermostat and associated hoses because I don’t want to be stuck on the side of the road somewhere. 148k
    DriverSound likes this.
