2nd gen Tacoma won’t go into program mode
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnjontroller, May 18, 2022.
  1. May 18, 2022 at 4:47 PM
    Johnjontroller
    Johnjontroller [OP] New Member
    Seth
    07 crew cab
    3” lift
    So I’m trying to enter my 07 Tacoma into program mode and have followed all the steps and it won’t go into program mode. I’ve unplugged the ecu and put it back in then tried again and nothing. Also unplugged battery and tried again and still nothing. Anyone know what might be causing this
  2. May 18, 2022 at 5:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What are you trying to program?
    reallifedog, Geeves77 and TnShooter like this.
  3. Jun 18, 2022 at 12:26 PM
    Johnjontroller
    Seth
    07 crew cab
    3” lift
  4. Jun 18, 2022 at 2:04 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
  5. Jun 18, 2022 at 3:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you don’t follow the circus act exactly it won’t go in to program.
    Follow the directions exactly.
    What directions are you following?
  6. Jun 19, 2022 at 9:20 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here are the complete process for programming the remote FOBS. You may want to clear everything and reprogram the truck to receive the FOBs you have. Note: The info in RED for other models.
    Try this. There are 4 modes. You should use Rewrite Mode to start over and only program the remotes you want to use.
    There are four different programming commands when setting up or verifying your remote transmitter, they are:
    1. Add mode, used to add a remote to your car that is not currently registered.
    2. Rewrite mode, used to erase all previously registered remotes and allow you to begin again the programming process.
    3. Confirmation mode, used to verify the number of remotes that are already programmed in your car.
    4. Prohibit mode, to prohibit all remotes from operating the door locks.
    https://www.carandtruckremotes.com/...eplacement-keyless-entry-control-remotes.html
    Procedure To Program Toyota Wireless Remote Transmitters:
    Begin with: The driver's door open and unlocked. Key out of the ignition.
    1. Insert and remove the key from the ignition switch 2 times within 5 seconds.
    NOTE: Steps 2 and 3 should be performed within 40 seconds.
    2. Close and open driver's door TWICE.
    3. Insert the key into the ignition and remove it.
    NOTE: Steps 4 - 6 should be performed within 40 seconds.
    4. Close and open the driver's door twice.
    5. Insert the key into the ignition.
    6. Close the door.
    NOTE: Steps 5 and 6 should be reversed for the following models ONLY (close door first, then insert key into ignition):
    2000 - 2005 Celica
    2001 - 2003 Prius
    2001 - 2005 ECHO
    2001 - 2005 RAV4
    2003 - 2004 Avalon
    7. Turn the ignition switch from "Lock" to "On" and back to "Lock" at about 1 second intervals to select the desired mode:
    1 time for ADD mode.
    2 times for REWRITE mode.
    3 times for CONFIRMATION mode.
    5 times for PROHIBITION mode.
    8. Remove the key from the ignition.
    9. To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a number of times corresponding to your key cycles in step 7.
    NOTE: If Confirmation or Prohibition modes have been selected, opening the door will complete the procedure.
    10. For Add or Rewrite modes do the following within 40 seconds of Door
    Procedure Lock confirmation:
    A. Press both car transmitter Lock and Unlock buttons simultaneously between 1 and 1.5 seconds and release.
    B. Within 3 seconds of step A, press the transmitter Lock button for more than 1 second and release.
    If the keyless entry remote transmitter has been successfully programmed, the power locks will cycle "lock" to "unlock" once at this time.
    If there are problems with the remote transmitter or the procedure up to this point, the locks will cycle twice. If this occurs, verify that you have received the correct transmitter, and then repeat the above procedure.
    C. If multiple remotes are to be reprogrammed, repeat steps A and B.
    11. Open the driver's door to conclude programming mode.
    bokch0y and TnShooter like this.
  7. Jun 19, 2022 at 7:24 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  8. May 14, 2023 at 5:15 PM
    Doogiemonstermd
    Doogiemonstermd New Member
    James
    2014 TRD quad cab 6 speed
    Stock so far
    When I try this and the power locks cycle, then press the remote entry key. . . Nothing happens! Locks do not cycle at all! Batteries are brand new in both remotes. Any ideas? I have unplugged the module under the passengers side dash. I have disconnected the vehicles battery for 20 minutes. Please, please help!
  9. May 14, 2023 at 5:34 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I used this method on my 2015 and it worked.
    https://youtu.be/BYd6ayq-Ivs
  10. May 14, 2023 at 6:42 PM
    Doogiemonstermd
    James
    Stock so far
    I tried this and no luck. I am starting to think maybe the module is somehow bad or both remotes are faulty? I opened them up and inspected/cleaned them when I replaced the batteries. Would the part # on the module give us a clue?
  11. May 15, 2023 at 1:23 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    I had an issue with this in the past and after trying everything I could think of unplugging and plugging back in the module ended up working.
  12. May 15, 2023 at 4:50 PM
    Doogiemonstermd
    James
    Stock so far
    I tried unplugging the module a week ago and also late last night with no results. I do find it weird that when I go into program mode the locks lock/unlock, but nothing happens after I press the buttons on the remote for the prescribed time. Remote issue? Antenna issue in the module?
