2nd Gen Thermostat Torque Spec?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokarl, Aug 16, 2015.
  1. Aug 16, 2015 at 4:36 PM
    tacokarl
    tacokarl [OP] Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    Been looking all over the internet and this forum for the torque specs for the 2nd gen style thermostat. Im sure I can just snug it down, I just like to know for the geeky side of me. Thanks guys, much appreciated!
  2. Aug 16, 2015 at 5:41 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    1GR-FE COOLING: THERMOSTAT: INSTALLATION
    1. INSTALL WATER INLET
    (a) Install a new gasket onto the water inlet with thermostat.
    (b) Install the water inlet with thermostat with the 3 nuts.
    Torque : 9.0 Nm (92 kgf-cm, 80 in-lbf)
    1. CONNECT NO.2 RADIATOR HOSE
    2. CONNECT BATTERY NEGATIVE TERMINAL
    Torque : 3.9 Nm (40 kgf-cm, 35 in-lbf)
    1. ADD ENGINE COOLANT See: Coolant\Service and Repair
    2. CHECK FOR ENGINE COOLANT LEAKAGE See: Coolant\Service and Repair
    3. INSTALL V-BANK COVER
    (a) Install the V-bank cover with the 2 nuts.
    Torque : 7.5 Nm (76 kgf-cm, 66 in-lbf)
  3. Feb 17, 2024 at 9:43 AM
    Lakeabilene
    Lakeabilene New Member
    that is for the v6 and might break the bolts on some other engines. How about the torque for the 2.7?
  4. Feb 17, 2024 at 12:48 PM
    TacoTuesday1
    FL
    FSM
    4.0 didn’t torque mine went by hand.
    torque specs are typically more important on internal engine components such as rod bolts.
