2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Aug 10, 2012 at 6:04 PM
    #141
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes it requires the Toyota Techstream software. Also if you get it turned off and them disconnect the battery it will revert back to on again (the default setting ).
  2. Aug 10, 2012 at 6:31 PM
    #142
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Dang, that stinks,
    I read someplace that a man took his gauges out and opened uo the backside and found the little type tweeter in there and basically removed a wire of sorts and killed it,
    May have been an earlier model and not the 2012 though.
  3. Aug 10, 2012 at 8:15 PM
    #143
    Jimmyh
    SC
    2012 Prerunner SR5
    I haven't looked into the newer models, but You're right the older ones had an integrated speaker soldered on the combination gauge circuit board.
  4. Aug 18, 2012 at 3:12 AM
    #144
    tacoidaho
    tacoidaho Well-Known Member
    Idaho
    09 TRD Sport Access Cab
  5. Aug 20, 2012 at 9:13 AM
    #145
    tacopoker
    tacopoker Member
    Texas
    Taco 4 banger
    D-Rings that swivel like factory!! See below.
    As I was thinking about adding more d-rings to my 2012 Taco to tie shit down with my engineering mind came up with this,
    1. Remove the front bed bolts.
    2. Measure the bolts O.D.
    3. Buy steel pipe that will freely slip over the bolts.
    4. Drill out the d-rings slightly bigger than the pipe O.D.
    5. Cut pieces of the pipe that are 1/32" thicker than the d-rings.
    6. Place a piece of pipe in the d-ring, slip the bolt thru the piece and
    install.
    7. Enjoy, Done deal.
    Since I'm an engineer and a machinist, I made my own pipe pieces on an engine lathe. I just turned the O.D. on a piece of bar stock smaller than the I.D. drilled in the d-ring, drilled and bored the I.D. bigger than the bolts O.D. and cut them of with a cutoff blade.
    Tools Needed;
    Dial Calipers or Verneers to measure O.D. and I.D.
    Breakover handle w/ wrench to fit bolts.
  6. Aug 20, 2012 at 6:38 PM
    #146
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    I need to do this, as it's annoying not having the front added D-Ring swivel.
  7. Aug 22, 2012 at 5:30 PM
    #147
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Litegide24:
    Thanks for the challenge! I will definitely look into this and see it I can find a better solution! Adding a 6cyl AC amplifier is an expensive solution. I will compile all of the info you have requested and have an in depth answer for you tomorrow!
    Cheers! -Scott
  8. Aug 24, 2012 at 5:30 PM
    #148
    stuart1996t100
    stuart1996t100 New Member
    stuart
    san diego
    96 4wd T100 longtravel
    deaver, king, built right, fuel safe, dj safety, crown performance, hanneman, general grabber, speedway engineering, willwood,
    05+ tacoma factory lower control arm polyurethane bushing upgrade,
  9. Aug 27, 2012 at 8:30 PM
    #149
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    The A/C amp is $100 and can be had for $70 online. This may not be as expensive if it provides the necessary signal from the amplifier. The wiring diagrams make no distinction between different functions between the v6 and 4 cyl on the amplifier besides the temp output. The hope is that they are plug and play between them.
    Edit: They are the same for v6 and 4...puzzling. Part number with A/C is 88650-04020
  10. Aug 28, 2012 at 6:18 PM
    #150
    ROLANDSRU
    ROLANDSRU New Member
    virginia
    S-runner step up bed
    LSD
    I replace the stock radio on my S-runner 2003 and install a pioneer cd,radio,dvd navigation system. But i can't locate the vss wire.
    can you help me out
  11. Aug 29, 2012 at 4:10 PM
    #151
    D44boy
    D44boy Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    can we add show your BASE MODEL to the original list of photo threads?
  12. Sep 12, 2012 at 1:41 PM
    #152
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    How does one get their how to thread linked in this sticky? In my sig is a thread that is a how to on making a rear view mirror bracket that can be made for a few bucks and can be used with all sorts of devices. I've had a lot of people tell me how helpful this is so maybe it should be linked in this sticky?
  13. Oct 7, 2012 at 5:17 AM
    #153
    heydude348
    heydude348 Active Member
    Tampa,Fl.
    03 Tacoma double cab TRD
    I have a 2003 Tacoma. Anyone have a good tutorial(video maybe) on how to replace the altrnator belt.
  14. Oct 7, 2012 at 7:30 AM
    #154
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Did you try PMing a mod?
  15. Oct 7, 2012 at 1:21 PM
    #155
    Ostrichsak
    Jer
    That sounds difficult. :D
    Edit: It wasn't! I PM'd the OP/mod of this thread and it was done within minutes. Now that's what I call service! lol
  16. Oct 7, 2012 at 1:38 PM
    #156
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I sent you a PM with a link for repairs.
    Edit: I just noticed you were on 03, the link may not help much unless you did an 05+ underhood conversion.
  17. Oct 14, 2012 at 6:33 AM
    #157
    discoy2k
    discoy2k Well-Known Member
    DISCO
    NOLA
    05 TRDSport 3" Iron Man Coil, Stealth
    2005 to 2012 Front End Replace,2010 TRD Interior,6x Escort Shifters, Escort 9500ix, Escort LIVE w/ 4G Data, 100% Stealth on Interstate,De-Badged Completely,5% Tint Blacked out,Iron Man lift,InfraRed military Humvee Spots, Drive in 0lite,Lexus/Fujisu NAV, dual 8in lcd sun visors, 2 10" kicker solobaric dvc 2ohm, phoenix gold 2000 watt, lunar 100watt @ 1/4 ohm,3 farad cap kicker 250watt,2800watt ,TRU-SINE inverter, dual HID bulb+HID fogs w/ mod, Roof rack,Westin Bull Bar, Manik Side Bars, Sirius/XM (HACKED) Undercover Bed Cover, bosch Wipers, Iridium Plugs, Undercover Bed Cover
    hello,
    this is not really a mod, but you may want to add to the list. the first run of shipped TRD sports did not come with a cabin filter installed, so people may want to check and add 1
    cheers,
    disco
  18. Oct 14, 2012 at 12:05 PM
    #158
    tacopoker
    tacopoker Member
    Texas
    Taco 4 banger
    IGR, Need Fog Lights.
    **Taco 2012 Prerunner 4 Cyl. Dbl Cab**
    Which Fog Lights would be the best buy? Are there any for other Toyota
    vehicles that will fit? Would also need wiring info.
    Thanks
  19. Nov 20, 2012 at 12:14 PM
    #159
    Throughhonor
    Throughhonor Well-Known Member
    Long Island NY
    2014 Tundra
    I need some help, All windows but my driver will not roll up or down. I checked fuses and that is not the issue. My truck might of experienced some salt water spray after the hurricane but I doubt that did anything, any input helps. I really dont want to go to the stealership to fix it, thanks in advance
  20. Nov 20, 2012 at 12:24 PM
    #160
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    Check the little black switch on your door. I turned it off on accident while cleaning. It kid proofs the windows :D
