2nd Gen. to get Remote Reservoir shocks or not?
Discussion in 'Suspension' started by luk8272, May 31, 2014.
  1. May 31, 2014 at 3:25 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    The title says it all. My understanding is that the remote reservoir simply adds more fluid to aid in keeping the shocks functioning cool while in operation. I don't do any high speed offroading, would it simply be wiser/cost effective for me to purchase the standard Icon VS 2.0 shocks without the reservoir? All I do is mild offroading and some mud riding, and because of work it is very seldom that I am able to do this.
    Now more specifically, I intend to replace my worn out Bilstien rear shocks and lift blocks with Wheeler's multi leaf add a leaf progressive pack (maybe the HD pack,) but I was trying to determine if I should use the 2.0 standard shock or the Remote Resi shocks.
    Any input on experience with the Add a Leaf packs would be appreciated as well as input on the shock options. I don't really see the need for the 2.5 shocks but I'm willing to learn if I have misinterpreted their application.
  2. May 31, 2014 at 3:26 PM
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    just get it
  3. May 31, 2014 at 3:42 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yep. And if you wheel hard enough to benefit from remote reservoirs, consider stepping up to the VS 2.5 shocks.
  4. May 31, 2014 at 3:50 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    ^ That's kind of where I'm at with it. I don't really need to spend that extra bit of money on something that I will never really use.
  5. May 31, 2014 at 6:10 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    At what point would someone want resi's?
  6. May 31, 2014 at 6:19 PM
    dmharvey79
    dmharvey79 Well-Known Member
    Dennis
    Northern Virginia
    It seems like you'd really have to drive the hell out of a truck, say 70mph across the desert for miles, to really need remote reservoir shocks. They do look pretty cool though.
  7. May 31, 2014 at 7:09 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Tacobrah: that's kind of what I was wondering, but based on what I think I know about them, I certainly don't qualify. But I was hoping for some reassurance. The remote resi is intended to supply the shock with additional fluid to lesson the amount of heat the shock experiences when under heavy use. Such as whoops in the desert or at the least high speed driving offroad. Anything causing the shock to compress/decompress rapidly.
    And as for as I know the 2.5 version is simply a larger diameter shock supplying that much more fluid for more dampening. Simply increasing the volume of fluid.
    That is just my take on the subject.
    Now I am making some assumptions here, first off that my understanding is correct, and that the 2.0 shock I intend to use is actually long enough for the lift that I have.
    The only other thing I question is which add a leaf pack would best suit my truck.
    The standard or the HD?
    That's why I was hoping people with these shocks and leaf packs would chime in.
  8. May 31, 2014 at 7:11 PM
    TacoBrah
    Sean
    I have the wheelers HD 3 leaf, with the Icon 2.0
    Its a nice ride, definitely stiffer than stock but not too stiff. Handles weight pretty good. Ive loaded 500-600 lbs in the bed and had no problems.
  9. May 31, 2014 at 7:40 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Well then the leaf pack issue is settled. I'll be calling on Monday to get this ball rolling.
