2nd gen TPMS on 3rd Gen Taco
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Simmy3, May 8, 2020.
  1. May 8, 2020 at 11:00 AM
    Simmy3
    Simmy3 [OP] Member
    2017 Tacoma 4x4
    Madison, Ms
    found some 2011 rims/tires with sensors. Will they work on my 2017 with programming?
  2. May 8, 2020 at 11:03 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    They should but from a 2011, they’re nearing the end of the battery life for the sensors so there’s no telling how long they’d last before needing to be replaced.
    Edit:
    They might not be fully compatible.
    Didn’t think of the upgraded monitoring on third gens with actual pressure read outs as opposed to the dummy light on second gens.
  3. May 8, 2020 at 11:07 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    No they will not. Different part number
    Lt. Dangle likes this.
  4. May 8, 2020 at 11:07 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Curious also, whether the 2nd gen TPMS gives enough info to work on 3rd gen.
    Also curious if 3rd gen TPMS will work on 2nd gen.
    On my Autel TS401 TPMS scanner, the vehicle selection differentiates between 2nd gen and 3rd gen, and will not read a 2nd gen TPMS if vehicle is selected as a 3rd gen, and vice versa.
    The TPMS are 315MHz for both 2nd gen and 3rd gen.
  5. May 8, 2020 at 12:07 PM
    Simmy3
    Simmy3 [OP] Member
    2017 Tacoma 4x4
    Madison, Ms
    Clear as mudd :) Same frequency? That sounds like it should? Anyone know from experience?
  6. May 8, 2020 at 12:09 PM
    Shellshock
    Iowa
    Pretty sure they work but only display the low pressure light, not the actual pressure readout like the third gen ones
    @Cav_BluTRD
    shakerhood and GHOST SHIP like this.
  7. May 8, 2020 at 12:20 PM
    Simmy3
    Simmy3 [OP] Member
    2017 Tacoma 4x4
    Madison, Ms
    Just told the fella I was out due to the tpms issue. He says they are off a 2011 4runner. Gen 5? Ya'll think that changes anything?
  8. May 8, 2020 at 12:48 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    This ^
    No lights. But doesn’t read numbers.
    ALI3N_123 likes this.
  9. May 8, 2020 at 1:50 PM
    GHOST SHIP
    GHOST
    Didn’t even think of the pressure monitoring (actual numbers). I retract my previous comment.
    :thumbsup:
  10. May 8, 2020 at 1:54 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Do your current factory wheels not have TPMS sensors?
  11. May 8, 2020 at 2:43 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Although the 2nd gen has the dummy light, the actual 2nd gen TPMS modules DO report the actual pressure. I use the Autel TPMS reader to check the PSI pressure in my tires, rather than using a gauge. So much easier.
    GHOST SHIP[QUOTED] and RocTaco like this.
  12. May 8, 2020 at 7:15 PM
    Simmy3
    Simmy3 [OP] Member
    2017 Tacoma 4x4
    Madison, Ms
    Yes my 2017 wheels have sensors. I want a second set of wheels and tires for winter. My stocks spin in wet grass. Want a second set with some KOs or KM3s
  13. May 8, 2020 at 7:41 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    You could get the wheels with the 4runner sensors and see if someone will trade you for the 3rd gen taco ones.
    That's what I did, straight trade sensors for sensors and now my stock steel wheels have snow tires and my summer alloys have TPMS
  14. Aug 15, 2021 at 5:38 PM
    Recce
    Recce Member
    2021 DC TRD Off-road
    It may be old info for this thread by now... I see that 3rd gen tpms sensors don't work in 2nd gen, and 2nd gen does not seem to work in 3rd gen. I just tried to use my 2011 2nd gen wheels on my 2021 Taco, entered the tpms id's via obd II port but it does not seem to register. As soon as I enter 3rd gen tpms id's again, all turns back to normal.
  15. Aug 15, 2021 at 6:16 PM
    eurowner
    eurowner Duke Sky
    Scoty
    No, will not work either way.
    2011 Tacomas are 2nd Gen.
    I have bought two different wheels that were on two different 2nd Gen Tacoma’s and they will it work on the 3rd Gen.
    T4R sensors work in 2nd Gen Tacomas which do not work in 3rd Gen Tacomas.
