2nd gen trans cooler concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DallasPre, Apr 23, 2010.
  1. Apr 23, 2010 at 7:27 PM
    DallasPre
    DallasPre [OP] Well-Known Member
    Dallas
    White 2wd
    5%tint,kick ass Stereo,remote start/alarm,K&N intake,Katzkin seat covers,Custom bed mat,de-badged,painted grillbadge blk,relocate horn,rearview camera mod,seat-belt chime mod
    Ok so i was just relocating my horns and when i was done i stood back and took a look. hmmmm... the trans. cooler is conveniently located in the only place where it doesn't get fresh air. so i took the grill off again to see what i could do about it. the trans lines are to short to turn it in any other location, so i got to looking and think that if i get some bulk line i can relocate it on the aluminum bumper just inside the lower grill. im also gonna need to make new brackets.
    the first thing that comes to mind when i saw this "mistake" was that Toyota intentionally did this to shorting the trans life. :censored: Has anyone relocated there trans cooler or have an opinion on why it is where it is.
  2. Apr 23, 2010 at 7:33 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    It's a conspiracy.:spy: When you least expect it, a little japanese midget is gonna jump out of your glove box and ass rape you and your little transmission too!!
  3. Apr 23, 2010 at 7:39 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    lolol I will now have nightmares. . . thanks
  4. Apr 23, 2010 at 7:55 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I'm sure Toyota had a reason for where they put it. And it could be that it is fine where it is and it doesn't need to be modified.
  5. Apr 23, 2010 at 8:11 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    I relocated mine for that same reason. Made some brackets and extended the lines. Sits right behind the lower grill to the left. Fresh air
  6. Apr 23, 2010 at 8:20 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    Have any of you guy's put a accurate temp Gauge in the line before and after your relocation to see if it really makes a difference? ....Just curious.
  7. Apr 23, 2010 at 9:32 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    I did not. But I wasnt really worried about the trans temp. I moved it mainly because I wanted it to stop blocking air from my intercooler.
    MTopp likes this.
  8. Apr 23, 2010 at 9:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The tranny cooler in the stock location gets plenty of cool air.
  9. Apr 23, 2010 at 10:35 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    and how do you know this....? seriously, just wondering....the guy below has a good suggestion...
    finally someone that speaks fact, not just hearsay or opinions...
    ^im w/ him...!
  10. Apr 23, 2010 at 10:57 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    I need some tinfoil for my new hat!
  11. Apr 23, 2010 at 11:33 PM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    It's its stock location, almost the entire cooler is hidden behind solid plastic.
    There is virtually zero air flow over it. Now logic would suggest moving that so that air does flow over it would increase its efficiency.
    I dont have stats to back that up, but then again I havent seen anyone here prove me wrong either.
  12. Apr 23, 2010 at 11:38 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ hidden behind plastic...virtually zero airflow... really...how much room is between this plastic and the front of the cooler?! you forget that air doesnt always go straight...it travels around things...
    i wish i had one of those handheld wind measuring devices to prove you wrong...anyone out there have one that they can mount to the front of the trans cooler?
  13. Apr 24, 2010 at 4:15 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    One of the members on TTORA installed a temp gauge and noticed that the OEM cooler was only performing moderate at best. He proceeded to add an aftermarket cooler for less than $100 in a location that received more airflow.
    Temps were recorded with both the plastic front bumper cover on and off the truck with the OEM cooler. Temps ran cooler with the bumper cover removed:
    http://www.tacomaterritory.com/forum/showthread.php?t=78433&highlight=atf+cooler
    Not my test - just passing on the results.
  14. Apr 24, 2010 at 6:13 AM
    DallasPre
    Dallas
    White 2wd
    Im with you. I mean ask youself. whats the number one killer of trans? HEAT. this is like a 30min mod that you may or may not need. but why not?
    i had a 94 explorer and i was driving back from houston to dallas and the trans started to over heat and blow trans fluid out the vent hose. so i went to autozone bought a trans cooler for an RV, installed it and never had the prob again.
    i think im gonna do the same for my taco.
  15. Apr 24, 2010 at 7:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is correct ^^^^^
    If the grill affected it that much, there would be a much smaller grill on the truck.
    its also a larger coooler than OEM. And yes, With the front grill and such removed, it will get sligtly more air flow.
    Look at it this way.....All the people that put a bank of lights in front of their radiator, If it was adversely affecting the flow that much, their trucks would be overheating. They are not, because it doesnt.
  16. Apr 24, 2010 at 9:30 AM
    Super Werty
    Arizona
    07 TRD Tacoma
    air and fuel
    Well I disagree. I believe there is a difference between something being open to air, and air moving across it. And I don't know if you are meaning to come off as rude right now, but it seems that way. If you don't want to do this simple mod then don't do it.
    Again, like I said, the main reason I moved mine was to get it out of the way of my intercooler. When I went from a stock grill to a grillcraft mx grill I saw a drop in coolant temps from the extra air flow. URD lists that grill as one of their recommendations for the MKII superchargr kit. Even they know air moving across a heat exchanger makes a difference.
    To each his own;)
  17. Apr 24, 2010 at 11:15 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    An interesting read. Thanks for posting that. It would seem that the bumper cover test does show that improved air flow helped cool the trans fluid quicker.
    After reading that, I now think that the location Toyota chose for the trans cooler was a compromise between winter and summer driving.
    Also, does anyone know if the transmission can stop fluid from circulating through the cooler if its too cold like in Alaska or Canada or does it always circulate through the cooler regardless of outside temperature?
