2nd Gen TRD OFF ROAD Vibrations After Lift Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NauticalWinter, Jan 3, 2024.
  1. Jan 3, 2024 at 8:48 AM
    NauticalWinter
    NauticalWinter [OP] New Member
    Jackson
    2009 Toyota Tacoma TRD OFF ROAD
    3 inch suspension lift kit (Eibach Pro with add a leaf), 33s, Custom Roof rack, Custom front winch mount, custom dual battery system.
    Hello everyone, I know that this probably has already started a thread, but I could not find it. So, if it has, please direct me to the right place.
    So, my issue is that I have driveline vibrations when I am accelerating. The vibrations mainly occur under 25 mph and are amplified if I am traveling up a steep hill. So, I assume that the vibrations are worsened when more torque is being exerted on the driveline.
    This started happening right after I installed my lift kit. I installed a 3 inch suspension lift from headstrong offroad. It is an Eibach Pro lift kit that came with struts, shocks, add a leaf, and upper control arms. Right after install I noticed the vibrations.
    These vibrations actually got a little more noticeable over time. After a little while, something started squeaking in my driveline. So, I went ahead and replaced all of my U-Joints and the Center Carrier Bearing. The squeak stopped after this operation, however the vibrations were still there.
    The time came when I wanted to resolve the vibrations. I started by getting a carrier-bearing drop kit, but that did not work. So, I then tried some axle shims, I got a 3 degree which should correspond to my lift. The vibrations were slightly better, however, they are still very present, especially when going up hill.
    Do y'all have any recommendations?
    Thanks in advance!
  2. Jan 3, 2024 at 9:56 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Possibly u joints in the driveshaft or carrier bearing is out, and clunking when shifting out of park?
  3. Jan 3, 2024 at 10:00 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    NauticalWinter[OP] likes this.
  4. Jan 3, 2024 at 10:02 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  5. Jan 4, 2024 at 8:17 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    Most likely (99.5%) that it is being caused by out of spec pinion angle .
    It is amazing that this is little known and often misdiagnosed by even "pro" off road shops and transmission "experts"
    I have been told it was everything from a carrier bearing to the torque converter , when the fix was just a set of wedge shims on the rear axle to bring the angles back in spec, you can't just throw some shims at it and hope to get lucky
    https://youtu.be/Hbu4yQa2kXo?si=k7xYerxkadXZd6nT
    If it goes on too long it could create other bearing problems
  6. Jan 4, 2024 at 9:01 AM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
  7. Jan 4, 2024 at 9:04 AM
    Waitin4Snowfall
    Waitin4Snowfall Member
    South Lake Tahoe
    2015 TRD OR DCSB
    I thought I had the same issue but it turned out to be the CV axle needle bearing.
    jaymac10 and NauticalWinter[OP] like this.
  8. Jan 4, 2024 at 9:13 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    any time you do a lift and wheels/tires on these trucks you need to do the front diff needle bearing. If you havent it could be failing from the added stress
  9. Sep 5, 2024 at 1:59 PM
    Waitin4Snowfall
    South Lake Tahoe
    2015 TRD OR DCSB
    Finally swapped mine out and the vibrations are gone. Do it now if you have them!
  10. Sep 5, 2024 at 7:51 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Does the vibration go away if you switch it into 4WD?
  11. Sep 5, 2024 at 8:21 PM
    Waitin4Snowfall
    South Lake Tahoe
    2015 TRD OR DCSB
    Prior to this swap yes it did. I'm guessing it's due to the axles being engaged once 4wd is on
  12. Sep 5, 2024 at 10:58 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    I believe my needle bearing needs replacement as I'm getting a humm and some vibes with my 2.5' lift.
  13. Sep 6, 2024 at 7:44 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    They will tolerate up to 2". Anything over that and issues arise, typically.
  14. Sep 6, 2024 at 7:58 AM
    Waitin4Snowfall
    South Lake Tahoe
    2015 TRD OR DCSB
    I was at 2" and it was vibrating a bit. Then 2.5" was a lot worse. Tried the driveshaft spacer, alignment, warming the truck up in the cold mornings, nothing helped. After the swap it's totally gone. One way to check is to try to jiggle the CV axle where it joins the engine. If there is a lot of play you probably need to swap out that damn needle bearing.
    RCBS likes this.
  15. Sep 6, 2024 at 8:07 AM
    RCBS
    I ran 5100s at 1.75 for 7 years, not a single issue. Threw an OME setup (2-1/2) on it and had vibes within a week.
  16. Sep 6, 2024 at 8:20 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
