2nd Gen Ultimate LED Dome and Map lights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by MESO, Jul 10, 2018.
  1. Mar 28, 2019 at 7:03 AM
    #2461
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    It's not the wiring. It's like the dimensions were off when it was 3D printed. It fits in there rather tight and when I press it to activate it, the entire thing stays depressed and the light does not activate. When I take the entire piece out, leaving the wiring installed, and push the switch to activate it then it works...only when it is installed it does not work correctly.
  2. Mar 28, 2019 at 7:09 AM
    #2462
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    They are marked “L” and “R”, did you verify the right side was insterted?
  3. Mar 28, 2019 at 7:31 AM
    #2463
    CoBackCountry
    J
    Colorado
    I certainly did, I do not believe it a user error issue.
  4. Mar 28, 2019 at 7:37 AM
    #2464
    MESO
    State of Jefferson
    Just checking. PM me the order number and what side, I’ll send another. Usually my 3D prints are spot on for dimensions, but there is always a chance of something.
  5. Mar 28, 2019 at 7:51 AM
    #2465
    CoBackCountry
    J
    Colorado
    Thanks, I'll be in contact later this evening.
  6. Mar 28, 2019 at 9:01 AM
    #2466
    superman2481
    superman2481 Well-Known Member
    BOOM! just ordered the Dome light
  7. Mar 28, 2019 at 10:30 AM
    #2467
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I see @mesojdm is taking care of you, but also check and see if the little plastic posts in the compartment that hold the light in place are bent. That can cause friction leading to the problem you’re describing.
  8. Mar 28, 2019 at 6:34 PM
    #2468
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Got my dome light installed yesterday and tested early this morning. Man is it bright! I’m mad that I wasted time and money on other LED’s. These products really are the best and brightest out there!
  9. Mar 28, 2019 at 7:44 PM
    #2469
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    X2 Agreed
  10. Mar 29, 2019 at 12:39 PM
    #2470
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
  11. Mar 29, 2019 at 12:42 PM
    #2471
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I had this same problem when I put mine in long ago. It was 100% user error. If those little pegs don’t clip in just right then it won’t work.
  12. Mar 29, 2019 at 2:00 PM
    #2472
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I blame the weak ass soft plastic posts inside the light recess. Meso’s material is much stouter.
    JKU3000 likes this.
  13. Mar 29, 2019 at 4:56 PM
    #2473
    JdevTac
    Josh
    MD/GA
    2nd gen
    Yeah they are pretty pitiful. All mine were okay except for one that bit the dust from prior changing to LED bulbs after I got the truck.
  14. Mar 29, 2019 at 5:13 PM
    #2474
    CoBackCountry
    J
    Colorado
    PSA: Apparently I'm a complete effin idiot and I did in fact have them installed incorrectly. Once installed correctly they operate normally and much more smooth. My humblest of apologies to @mesojdm!
  15. Mar 29, 2019 at 5:55 PM
    #2475
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    You have to respect a man who owns up to his mistakes.
  16. Mar 29, 2019 at 7:49 PM
    #2476
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    ^^^ Very much this.
    Beretta4x4 and JKU3000 like this.
  17. Mar 30, 2019 at 8:45 AM
    #2477
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    How do you remove?
    EDIT: Update- just snatched them out with tiny pliers. Install was fine except the front driver side mounting clip failed when I pressed in the new lamp so I'm kind of screwed.
  18. Mar 30, 2019 at 9:09 AM
    #2478
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    carefully... the reflectors are held in with tension from the reflector itself on a post. they are easy to break, especially if they are older and brittle. gently work it back and forth while pulling.
  19. Mar 30, 2019 at 1:54 PM
    #2479
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    JKU3000 likes this.
  20. Mar 30, 2019 at 8:48 PM
    #2480
    stevencand0
    stevencand0 Member
    I'd like a set of red/white map lights when they are in stock again
