2nd Gen Ultimate LED Dome and Map lights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by MESO, Jul 10, 2018.
  1. Oct 13, 2020 at 5:19 PM
    #3121
    Hunter_Bick12
    Hunter_Bick12 Just a Yota guy
    Hunter
    Alabama
    2011 Black DCSB TX TRD Prerunner, 1986 Gray SR5 4x4
    I just came here to say.. excuse my language, but holy shit these things are bright! I wish now that I would’ve gotten all red dome though. Would’ve been plenty bright enough especially considering I got all white maps.
    dnl_tacoma likes this.
  2. Oct 13, 2020 at 5:33 PM
    #3122
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    My dome light showed up today. Will be painting & installing soon. Thanks @MESO :thumbsup:
    dnl_tacoma and ovrlndkull like this.
  3. Oct 13, 2020 at 6:46 PM
    #3123
    Hunter_Bick12
    Hunter
    Alabama
    I also had a glow after testing them and turning them off. Referring to dual color dome, it only happened on the white LED’s. Will check again in the morning. Is this something to be concerned about or?
  4. Oct 13, 2020 at 6:50 PM
    #3124
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    I've got way to much bass in my truck for that little festoon to cut it.
    Stayed in place maybe 5 seconds when turned up.
    Would it be possible for me to cut off the supplied festoon end then solder one of these festoon adapters like this one on the right in pic?
    scott_b and WRDD Taco like this.
  5. Oct 13, 2020 at 7:03 PM
    #3125
    WRDD Taco
    WRDD Taco Big Hobby Guy
    Jake
    Delco, PA
    ‘11 TRD Sport DCLB LT 1G3 Moto Express
    TC Mid Travel +2, TC SUA, king shocks, Swamp Donkey/Rigid lighting, Mechman alt, SOS/Boztek armor, ATH Fab tiedown, full active JL/Audiofrog sound system, NOICO sound deadening EVERYWHERE. Up next: roof/bed rack + dry storage, skids, bumpers, fiberglass, power wire upgrade + frame grounds, LTO battery swap, air compressor, on board pressurized water, powered cooler, suspension seats, frame reinforcement, solid motor/trans mounts.
    yeah I just figured that out today after I installed mine. I just wrapped tin foil around the butts and that seemed to keep it in place better.
    Jacked Burton[QUOTED] likes this.
  6. Oct 13, 2020 at 8:26 PM
    #3126
    Dark505
    Dark505 Well-Known Member
    Geoff
    NoCo
    2010 BSP DCSB OR. Dark Vader
    I just gotta say... holy crap these are bright! Haven't used while on the road but.... this is a pic from the outside. I have 5%tint on my windows
    dnl_tacoma and WRDD Taco like this.
  7. Oct 13, 2020 at 10:50 PM
    #3127
    Tsinajinii
    Tsinajinii Black Wood Streak People
    Jamin
    AZ
    2011 DCLB 4x4 TRD Sport
    OME 885's paired to Bilstien 5100's, LR UCA's, OME Dakars w/ 5160's, Debadged Tailgate, TRD Stickers Removed, ARE Topper, Tailgate Theft Deterrent Mod, Mobtown Tailgate Skin, Light Bar in Hood Skewp, VIAIR OBA, Diaz Fabrication - T.H.R.B., Always on Cig. Outlet, BAMF behind the grill light mount with KC HiLites Pro Halogens, KC HiLites Flex ditch lights
    Received my dual dome light this evening.
    Pulled out my original Meso all white dome light from two years ago out to get the new one in.
    Below are some pictures.
    I gotta say, I’ve always considered @MESO ’s stuff to be top notch (I also have his 2nd Gen Dual Map’s as well as his overhead Molle Rack) but the fit & finish of these injection molded parts are top notch!
    Well worth the wait to get these updated dome lights.
    Kudos @MESO !!! :cheers: Job well done!
    New version on the left, old on the right:
    dnl_tacoma, ovrlndkull, 74cam and 3 others like this.
  8. Oct 14, 2020 at 4:39 AM
    #3128
    scott_b
    scott_b Well-Known Member
    The Old North State
    '12 TRD Sport AC MT
    Your explanation was cut off.
    JKU3000 likes this.
  9. Oct 14, 2020 at 5:30 AM
    #3129
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    My guess is the 3rd gen units use the smaller festoon and this saved production costs between 2nd/3rd gen. I don’t like having to pinch fit this thing and at the end of the day it is not the correct width, but it works. I guess if it wont come on anymore I know it’s probably popped out of place.
    That being said it looks fantastic in my GX470 with a 2nd gen dome. I even painted beige to match
  10. Oct 14, 2020 at 8:06 AM
    #3130
    CoBackCountry
    CoBackCountry Well-Known Member
    J
    Colorado
    MESO sent you a pm and received no response from you, so I guess I'll post my issue here.
    I have your ultimate map lights, have had them for about 2 or 3 years at most. Recently had the white leds go out on left side, all but one strip...and 2 strips on right side went out. All the red leds work. Is this is a known issue or can I send them back to you to have them fixed and mailed back to me, as I don't know what exactly the problem is.
  11. Oct 14, 2020 at 10:09 AM
    #3131
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Installed the map lights, although they get stuck. In that when I press them up, they dont pop back down to turn on. I still have the original reflectors installed, is that the cause of the lights getting stuck?
  12. Oct 14, 2020 at 10:14 AM
    #3132
    Tsinajinii
    Jamin
    AZ
    Yes. They will work better with the original reflectors removed.
    I made the same mistake when I first installed mine as well.
  13. Oct 14, 2020 at 10:15 AM
    #3133
    Camby
    Brian
    Denver
    Great I’ll take them out.....em...how does one take them out??
  14. Oct 14, 2020 at 10:33 AM
    #3134
    chetterthecat
    chetterthecat Well-Known Member
    OR
    13 sport
    I yanked em, but I has no interest in saving them.
  15. Oct 14, 2020 at 12:50 PM
    #3135
    Hunter_Bick12
    Hunter
    Alabama
    I still have reflectors in and have no issues. I think the issue is the very small plastic piece that meso’s light tabs snaps onto. If they don’t line up perfect, and snap into place, it doesn’t seem to work correctly. I played with mine forever and finally got it to work without any “stickiness”. Reflectors still in. Not saying it doesn’t help to take them out, but I don’t think it’s the main issue.
  16. Oct 14, 2020 at 1:17 PM
    #3136
    CoBackCountry
    J
    Colorado
    I had that problem when I originally installed mine, unbeknownst to me I had them installed backwards....as in the drivers side was on passenger side, and the passenger side was installed on drivers side. Once I switched them, they worked perfectly fine. I may be wrong but I believe they should be marked with either a L/R for left and right or a D/P for drivers side and passenger side
  17. Oct 14, 2020 at 1:32 PM
    #3137
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Just to chime in here..
    Both sides are the same. There may be small amounts of tolerance variations on the posts they snap into, the overall perimeter of the plastic overhead, and my plastic housings. They were designed to be tight, so if they are hanging up try swapping sides and even cycling them a dozen times by hand to loosen up the plastic posts. It also helps to remove the chrome reflector to give the wire more space to move. Hope this helps
  18. Oct 14, 2020 at 2:44 PM
    #3138
    theolee
    Theo
    SAN DIEGO
    Painted, installed and ready to roll. Thanks @MESO
    :mudding:
  19. Oct 14, 2020 at 2:57 PM
    #3139
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Any ideas about the residual glow in the LEDs? Not a deal breaker, and I still love the product, but would feel a little better without that situation.
    dnl_tacoma and ProfessorWiggins like this.
  20. Oct 14, 2020 at 3:40 PM
    #3140
    Jacked Burton
    [​IMG]???
