2nd Gen Ultimate LED Dome and Map lights
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by MESO, Jul 10, 2018.
  1. Sep 22, 2018 at 4:16 PM
    #1561
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    Nice compression shot :thumbsup:
  2. Sep 23, 2018 at 8:12 AM
    #1562
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    Son of a....I’ve been waiting to get a done light for almost 2 months now and every time I see them available they’re sold out when I click the link
    Stryker420 likes this.
  3. Sep 23, 2018 at 1:03 PM
    #1563
    jimlmackjr
    jimlmackjr Well-Known Member
    JimE
    Harker height,Tx
    Toyota Tacoma TRD Pre Runner Sport Long bed
    Tacoma beast headlight Meso mods inside lights Trd pro grill Hooke road roof rack BFG KO2 Roam RTT
    Damn USPS. Lost my package was supposed to be delivered Sat now it looking like Monday. Gurrrr
  4. Sep 23, 2018 at 1:06 PM
    #1564
    pilau
    pilau Well-Known Member
    Las Vegas, Hawaii
    2015 DCSB Tacoma PR
    came in on saturday and installed on sunday! now I need to get the dome for 2nd gen!
    thanks MESO
  5. Sep 23, 2018 at 1:58 PM
    #1565
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    lol i wouldn’t call that being lost
    usps does that crap alllll the time they suck’
  6. Sep 23, 2018 at 5:18 PM
    #1566
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Hey guys. Getting a little frustrated here with the dual color maps and hope someone can help me out. I took the old bulbs out and put in Meso's dual color map. I plug it in, check it to make sure it turns on, and I go to snap the light unit on. When I put the actual light unit back in the lights flicker on/off as I try to tuck the wires. I figure the reflectors are in the way so I take them off for both sides. I re-plug Meso's maps and check them to make sure they work - yes they do. I do the check for both sides before snapping the maps in place. Once I do that both map lights do not work. I'm thinking to myself 'What the hell is going on?!' So I pop them back off, keeping them plugged in, and manually press the on/off white button for both sides. Nothing! Both sides aren't working now!!
    What the heck am I doing wrong? Help :(
  7. Sep 23, 2018 at 5:23 PM
    #1567
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    First thing I would check is Make sure the t10 bulb adapter connector leads are straight and making proper contact like this:
    Bravisimo likes this.
  8. Sep 23, 2018 at 5:27 PM
    #1568
    jimlmackjr
    JimE
    Harker height,Tx
    Check your fuse just in case. I've not got mine yet so can't help there
  9. Sep 23, 2018 at 5:31 PM
    #1569
    JoeTacoma02
    Both sides looks good. I tried putting the old OEM bulbs back on to check and they won't turn on anymore either. Did I break something lol
  10. Sep 23, 2018 at 5:35 PM
    #1570
    MESO
    State of Jefferson
    Plug a stock bulb back in and verify power is still going to the circuit
  11. Sep 23, 2018 at 5:35 PM
    #1571
    JoeTacoma02
    Which one do I check or how do I know which fuse has popped if that were the issue? I popped it open and they're all still properly seated.
  12. Sep 23, 2018 at 5:35 PM
    #1572
    MESO
    State of Jefferson
    Under hood. Should be a 7.5a? I think the dome and maps are off same fuse on 2gens..
  13. Sep 23, 2018 at 5:38 PM
    #1573
    JoeTacoma02
    Found it. How do I tell if it's bad? I pulled it off and reinserted it. Tried the oem bulb again with no luck.
  14. Sep 23, 2018 at 5:40 PM
    #1574
    MESO
    State of Jefferson
    You can pull it out and look(they are semi-see through) but the best way is with a multimeter on continuity. When in doubt just swap another in(should be some spares in the fuse box cover)
  15. Sep 23, 2018 at 5:43 PM
    #1575
    JoeTacoma02
    Oh lawdy now the dome doesn't work lol I should have just stuck to your domes that I already had installed ;(
  16. Sep 23, 2018 at 5:50 PM
    #1576
    JoeTacoma02
    Ok so I put a 10a fuse in place of the 7.5a (assuming that's okay) and now the dome I got from you is working as well as the oem bulbs for the map.
  17. Sep 23, 2018 at 5:57 PM
    #1577
    MESO
    State of Jefferson
    PM’d
  18. Sep 23, 2018 at 5:59 PM
    #1578
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Installed the white dome light today. I love the light. I don’t think it is too bright, unless you look directly at it. I was going to go with the dual maps when they are available, but now I think I will go with the white maps. I love the light and the brightness.
  19. Sep 23, 2018 at 6:02 PM
    #1579
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    Dome lights going to be available for 2nd gen again? Think many are anxiously awaiting overhead console switch panels for 2nd gen also.
  20. Sep 23, 2018 at 6:02 PM
    #1580
    MESO
    State of Jefferson
    The best part about the dome design(besides the awesome light output) is that the LED’s are recessed in the housing. What this does is channel the light down where it’s needed, and not out the side blinding you like a conventional LED bulb swap + factory clear lens.
    T@co_Pr3runn3r likes this.
