2nd Gen Upgraded Headlight Styles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JAHGB2, Feb 20, 2024.
  1. Feb 20, 2024 at 6:44 AM
    JAHGB2
    JAHGB2 [OP] Well-Known Member
    Pennsylvania
    2010 TRD Sport DBL CAB Pyrite Mica
    I still love the Spyder headlights I bought for my Taco 5 years ago (a style offered by other manufacturers at this point). However, while searching for 2nd gen grilles, I found this website that shows a headlight style I have never seen before and can't find anywhere. Has anyone seen these and knows where to purchase? I'm thinking ahead: if I never sell my truck and need new headlights down the road, I'd consider these for a new look. I couldn't find them on the site listing the grille.
    https://www.ledfactorymart.com/coll...-gen-2005-2011-front-grille-for-toyota-tacoma
    tacoma-headlights-Roxmad 2nd Gen 2005-2011 Front Grille For Toyota Tacoma.png
  2. Feb 20, 2024 at 8:04 AM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    JAHGB2[OP] likes this.
  3. Feb 20, 2024 at 8:10 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Get yourself a set of true projector retrofits and never look back!
  4. Feb 21, 2024 at 11:32 AM
    JAHGB2
    Pennsylvania
  5. Feb 21, 2024 at 1:09 PM
    EveryDayIsTacoTues
    Yep, you'll find that with most aftermarket headlights. Like Tego said, you can do the retrofit which is what's highly recommended. But if you're comfy with Spyder and have good experience/performance with them, that's what matters. Usually Morimoto are a solid aftermarket, issue is they don't make a 2.0 replacement. So that'd leave AlphaRex aside from Spyder or Depots.
  6. Feb 21, 2024 at 1:47 PM
    TacoTuesday1
    SD CA
    10x worse looks and light than a DEPO for the same price Hell Yeah Brother
    You know what you can do?
    Make sure you have a good harness, housing, and/or bulb.
    Then get whatever that crap is, and compare it. If it's not good, you might potentially be able to return it money back. And then you will know.
    Generally, when people put a good projector
    it's because they pick a good projector. They're not all equal. Folks do their research and see what fits. Which is a project. And that "good projector" is usually something that at some point has been chosen by OEM's for that reason. Not eBay.
    For example. Bosch AL E46 gen2/3 3" bi-xenon HID D1S
    A lot more involved. Disassembling, cutting, etc.
    More often done on passenger cars because they have tiny headlights that can't fit anything else.
  7. Feb 21, 2024 at 11:45 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    OEM will easily outperform them all. Especially the AlphaRex (rebranded chinese crap) or Spider (regular chinese crap). All aftermarket lights will be a downgrade from 2nd Gens OEM headlights, and those particularly as well as the ones mentioned in the original post will be really awful.
  8. Feb 22, 2024 at 10:27 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    Yeah, stay as far away from Spec-D as you can. They are well known for fogging/leaking issue across multiple different platforms.
  9. Jun 17, 2024 at 7:57 PM
    Smills91
    Smills91 Well-Known Member
    Is there an oem housing with a dark background and/or smoked lens available?
  10. Jun 18, 2024 at 6:41 AM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    Look at this thread. There are two different sets of OEM lights linked, one is the smoked lens available on the 2011 TRD Sport, the other is the Pro lens on the 2012+
    The ultimate headlight upgrade H4 (not LED or HID) | Tacoma World
  11. Jun 18, 2024 at 10:35 AM
    JIGNE67
    JIGNE67 Well-Known Member
    Sherman Oaks, CA
    2015 Tacoma TRD Sport DCSB
    Those headlights are nice and that grill is pretty cool.
    I recently installed these Morimoto XB Hybrid LED Headlights and Morimoto 4-banger LED Fog Lights on my 2015 PreRunner.
    They are so much brighter then the stock ones (I'm holding on to the OEM ones though).
