2nd Gen V6 manual to auto swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Jan 11, 2012.
  1. Jan 11, 2012 at 11:25 AM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    Did a search and all that turned up was info about going from an auto to a manual. I have a 6 speed in my 09 V6 4x4, but wondering how involved it is to swap it out for an auto. What do I need from the donor vehicle?
    "Sell it and get an auto" doesn't help me as I have no intention of selling the truck. Just curious,
  2. Jan 11, 2012 at 11:58 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    My guess would be a lot. Apart from transmission, all the computers, plus wiring for them, plus the dash. That would only work if you can find the same truck, the same year with auto transmission and simply pull everything out of the salvage.
  3. Jan 11, 2012 at 1:52 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    You're better off selling yours and buying an auto.
    (Yes I read that the OP didn't want to do this)
  4. Jan 11, 2012 at 1:53 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    X2
  5. Jan 11, 2012 at 6:10 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Let's see....transmission and possibly transfercase if it's a 4x4, driveshafts?, trans mount?, trans shifter cable and center console parts, instrument cluster with trans indicator in it, wiring harness and PCM from an auto truck, radiator with trans cooler in it, cooler lines, flexplate, maybe the starter?, pedal assembly, parking brake mechanism and cables, maybe the brake master cylinder reservoir (mine feeds the clutch as well, wouldn't need that on the auto).....that should get you started. Good luck, doesn't sound like a whole lot of fun to me.
