2nd. Gen. V6 Secondary Air filter removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airsoft_warrior, Oct 6, 2008.
  1. Oct 6, 2008 at 9:33 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I didn't notice a write up on the V6. So i figured I would write one.
    First off what you need:
    10mm Socket wrench
    Flat head Screw Driver
    Phillips head Screw Driver
    (Optional: Electric Drill/Drill bit)
    I don't Have pictures at the moment but i will post them.
    1. First off start by lifting the engine cover by undoing the 10mm bolts holding the cover down. You can pull the cover off and set it out of the way.
    2. The MAF sensor is on top of the airbox. Undo the Sensor.
    3. Once undone, Loosen the air hose by unscrewing the Clamp on the hose.
    4. Undo the clamps on the airbox to open the box to reach the primary filter.
    5. remove the primary filter box and primary filter. Just set them aside.
    6. On the part of the airbox that remains is the secondary filter. There are several options to remove this:
    • Use the flat head screwdriver to pry each of the plastic holders that are built into the airbox. You will have to break the holders to get it out
    • Option 2 is to drill them out (I don't recommend this because the filter box is still in the engine and it is really messy and a pain to get all the plastic shavings out before you start the engine)
    • just cut the filter out and use a little force to pull it out.
    And your done. Just clean out any debris that may remain.(this is important you don't want the plastic in the engine) and put it all back together. Don't forget the MAF sensor.
  2. Oct 6, 2008 at 9:58 PM
    mitiko
    mitiko Well-Known Member
    lax
    05 prerunner trd
    do you have any difference in a gas millage.
  3. Oct 6, 2008 at 10:06 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    No
  4. Oct 6, 2008 at 10:21 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    What is the purpose of doing this?
    Thanks-
  5. Oct 6, 2008 at 11:33 PM
    slimsdepot
    slimsdepot slimsdepot.com
    SoCal
    08 PreRunner
    Yea I am curious too... I have seen this DIY before and wonder if there is a real reason for it.
  6. Oct 7, 2008 at 3:23 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I've done it, hoping for even a marginal improvement in MPG. Instead I lost a MPG. I re-installed it. You would think the slightly better airflow with it removed would help performance and MPG, but neither happened. For me anyway. Others have had different results.
  7. Oct 7, 2008 at 3:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Throttle response....
  8. Oct 7, 2008 at 5:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.........when i did it on the 06 i had.......i noticed throttle response was a touch better, but the truck idled better, and so that was worth it to me there. no noticeable mileage gain without the sec. filter on the v6, but i have heard its alot different on the 4 banger.
  9. Oct 7, 2008 at 9:01 AM
    slimsdepot
    SoCal
    08 PreRunner
    Makes me curious to try it but I don't know how to measure my MPG I always forget to reset my miles after fillups etc. and can't afford to lose MPG since I drive everyday for work non stop.
  10. Oct 7, 2008 at 10:07 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    To increase throttle response and Increase in MPG in the 4 cylinders. If its combined with a CAI or alternate filter, i have heard good things. and with a exhaust system too, people say it enhances MPG. Not a huge difference on the V6. But for those who want to do it.
  11. Oct 7, 2008 at 10:16 AM
    DFPTaco
    DFPTaco It's TACO time!
    Josh
    Las Vegas, NV
    19 DC SB TRD OFF ROAD
    little lift, wheels and tires, prinsu rack, TRD Pro grille, some lights, and some scratches.
    I think that any time you add more air into the engine you will LOOSE fuel economy. Truth is that the engine's computer adjusts fuel levels to match that of the air levels for a stoich running condition. So if you add more air with out fuel you would run lean and that's not good so the engine would add more fuel to compensate therefore decreasing your fuel economy.
    Someone let me know if I'm wrong here....
  12. Oct 7, 2008 at 10:49 AM
    Ken Dawg
    Ken Dawg Well-Known Member
    EAST COAST
    08 Prerunner TRD Sport LB
    Tranny rebuilt 12/2016 at 142,500 Pioneer deh-p400ub head unit Alpine spr-69c fronts Alpine 17c rears. Rockford Fosgate 4 channel amp JL sub behind seat Upper console solder fix Recall: Rear leaf's 12/2016 To Do List: JVC KW-V820BT with Backup cam Zelwig Helper Spring Clazzio Dark Gray seat covers /heat Viper alarm w/ Starter Then drive to 250,000 miles!
    I did it...response is better down low and when you are speeding up after slowing down for person in front of you turns off road...just seems easier on engine in those instances... as for mpg too early to tell. educated guess is nada either way. seems as if stock was a tad rich and this may lean it out a little...its a wash.
    so...
    for me the only real difference is low end and back up to speed seems to be less taxing on engine.
    does this help anyone? Not really....LOL
    dfpt...did ya get engine build info on harley? LOL
  13. Oct 7, 2008 at 3:56 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Does a CAI add more air into the engine? My intake tube takes air from the front fender (i find that strange) but with a CAI it takes it from the air within the hood. therefore adding more air. But CAI increases fuel economy. is my thinking logical or am I wrong in assuming how the CAI actually works?
    If i am right then shouldnt removal of the filter increase fuel economy too?
  14. Oct 7, 2008 at 4:44 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    The idea with a most cold air intakes is that it reduces the pressure and allows air to flow more freely into the motor, also, cold air is more dense so you will get more air = more oxygen, in the same volume of space compared to if the air was warm. Thus improving power and usually gas mileage at the same time.
