2nd gen V6 water ingestion?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bmgreene, Dec 7, 2009.
  1. Dec 7, 2009 at 3:58 PM
    bmgreene
    bmgreene [OP] Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    tried searching "water ingestion" and didn't get much, so....
    I'm getting into my first rainy season (never will describe anly L.A. weather as "winter") in my new V6 pre-runner (off-road pkg).
    Since it looks like the stock intale pulls air from the RHS front wheel well, I'm wondering about the possibility of sucking up dangerous amounts of water when crossing puddles.
    Also, are the 265 A/Ts prone to hydroplaning? (I've been driving a coupe with low-pros and Toyo Proxes with good channeling for the last 5 years) The tread looks like it shouldn't have any issues with wet traction, but there is an awful lot of air in those things, and they're spec'd for lower pressure than what I've been running on the rocket sled.
  2. Dec 7, 2009 at 4:01 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    Are you talking about puddles or deep water (whilst 4 wheeling)?
    I would think that the engineers at Toyota have elimnated the chances of puddle water getting sucked into the engine. Possibly why you didn't find anything when searching. I think you'll be fine.
  3. Dec 7, 2009 at 4:22 PM
    bmgreene
    Brian
    L.A. Westside
    thanks guys.
    I had kind of envisioned the possibility of the wheel kicking up water into the well right about where the air intake seems to be pulling from.
    might just be that I'm an engineer myself and prone to overthinking sometimes, although I had a '97 V6 a while back which had a couple bits where it lookled like the guys at Toyota had outsmarted themselves (oil fill directly above the alternator and the cupholders located directly above the head unit are the main two that stand out in memory).
  4. Dec 7, 2009 at 4:38 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    It'll be fine... first night I took it home we had a huge storm and I found some huge parking lot puddles to tear through at about 40mph kicking up about 20' waves.
    As for the hydroplaning.... you need to be careful about the rear of the truck, it can slide out on water pretty easily as there's no weight on the tires. It'll handle very well in the rain but you just need to get a feel for it... it's way diffrent than low pro's on a sports car (I came from a lowered G35 so been there). With the exception of the back wanting to kick out pretty easy... it feels a lot more stable to me.
    Also keep in mind your rear dif is open, not LSD.
  5. Dec 7, 2009 at 10:54 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    10 DC TRD O/R PreRunner SexyAss Barcelona Red
    TRD Drop-In, TRD Exhaust, OEM Roof Rack, N-Fabs, WeatherTech Liners, LED Interior Lights, Devil Horns Emblem, 2011 Painted Grill, Debadged with Sockmonkey TRD Badging only, Katzkins Leather Int; Next: 5100s/Eibachs
    the intake is in a pretty good hiding spot. if travel through deep water at a steady speed the wake helps push the waterline down lower around the front wheels. the air isn't pulled directly from the wheel well.
    also, the actual intake is designed to remove a some water if it gets sucked it in.
    there is a video demonstrating this on FJs on the toyota site.
  6. Dec 8, 2009 at 12:24 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    theres always water traps in intakes anyways. Woudln't worry about it unless you're doing a short ram style CAI.
  7. Dec 8, 2009 at 1:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When your truck ingests a dangerous amount of water...You'll know it - because it'll STALL. If you search for - "Hydrolock" or "Hydrolocking", you'll find more information.
    You don't have to worry about general driving or puddles. If you start diving into mud holes and deep water, then you could possibly hydrolock. The best advice when you do and the truck stalls, DO NOT TURN THE KEY!!!!
  8. Dec 8, 2009 at 1:18 AM
    brian
    Elizabeth City, NC
    I did that on my old ranger for about 15 minutes, kept cranking the key and eventually it turned over. Ran for about 15 minute on only 3 cylinders, eventually pulled out of it no problems. :p :p
  9. Dec 8, 2009 at 3:08 AM
    Janster
    Jandy
    Lancaster, PA
    You were LUCKY.
    If there's water in the cylinders and you try to start the truck, you'll bend a rod and TOTAL the engine.
  10. Dec 8, 2009 at 4:03 AM
    brian
    Elizabeth City, NC
    Yup, I know it... LoL I was young and didn't know anything at the time. Probably didn't have it that bad, betting I just fouled the plugs more than anything. I went through a 3 foot deep puddle at about 20 mph trying to be a hot shot. Made it through, but the intake on the older rangers is right on the grill, too much water and it went straight through the water trap. Fouled it up once I got out of the puddle.
  11. Dec 8, 2009 at 6:16 AM
    JNL
    JNL Well-Known Member
    Jamie
    Atlanta
    08 DC Prerunner TRD Sport
    I came from a lowered G35 as well, with 255's up front and 285's in the rear, so it would hydroplane pretty easily.
    The one thing i don't like about my taco is somehow when driving through puddles, half of the water ends up on the windshield, temporarily blinding you at the precise moment when you hydroplane.
  12. Dec 8, 2009 at 6:19 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
    I have noticed that mine does the same, as soon as I hit a bigger puddle the spray always tends to go right on the windshield...just wierd.
  13. Dec 8, 2009 at 9:43 AM
    bmgreene
    Brian
    L.A. Westside
    I've seen the "after" of a hydrolocked engine, a former coworker had a piston with a boomerang shaped rod attached as a paperweight from an old Honda which had managed to fill an entire cylinder. That's why I was so concerned about the possibility of it happenening to me....
  14. Dec 8, 2009 at 9:53 AM
    bmgreene
    Brian
    L.A. Westside
    My other car (which has been my DD for the last five years) is a lowered RX-8 with 245s all around. I was always really careful on the stock tires and haven't noticed any wet traction or hydroplaning issues since I switched to Toyo Proxes T1-Rs, although the car does manage to kick the bulk of any puddles I hit right into my windsheild (I was hoping the Off-Road PreRunner would be high enough to avoid that somewhat)
  15. Dec 8, 2009 at 3:23 PM
    Janster
    Jandy
    Lancaster, PA
    When or if it happens, you'll know it. The engine will stall.
    I've been offroading for 8 years and have helped revive many vehicles that hydrolocked. Only one situation, the guy turned the key and he bent a rod. He was EXTREMELY lucky that his insurance company covered everything - since the truck was a complete loss.
