2nd gen water leak on passenger side floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma guy, Jan 23, 2020.
  1. Jan 23, 2020 at 4:48 PM
    tacoma guy
    tacoma guy [OP] Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys, so I have red through alot of threads. I am a little confused. What exactly leaks after having the windshield replaced?... Here is where I am having the leak. It is leaking down in behind the kick panel and pudding on the floor under the carpet of the passenger side. I am not understanding what leaks after having the windshield replaced?
  2. Jan 23, 2020 at 7:37 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    The cowling for the AC air intake
  3. Jan 23, 2020 at 7:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Typically that leaks in to the Air Box that contains the Cabin Filter and Blower Motor.
    Since he says it started AFTER the replacement windshield was installed.
    I’m going to say it is inadequate sealant or adhesive.
    A faulty installation is likely the reason it leaks.
    grrck and Skyway[QUOTED] like this.
  4. Jan 23, 2020 at 7:48 PM
    Skyway
    Ande'
    St.Pete
    Right-On
    :drunk: Cheers!
    TnShooter likes this.
  5. Jan 23, 2020 at 7:52 PM
    TnShooter
    Deogee
    STOCK
    OP,
    If you feel inclined to try and find the leak yourself.
    You can have a friend run a water hose over the windshield while you look up under the dash.
    You’ll likely need to pull the kick panel and glove box. Maybe a few other things.
    I’d personally let place that installed the windshield take a look at it.
    I don’t really like working upside down or in cramped places if I don’t have too.
  6. Jan 24, 2020 at 3:41 AM
    tacoma guy
    Joe
    Phoenix Az.
    That's what I thought they were saying. So I guess there is no need to replace the cowl then?.. Thank you for clearing that up for me.
  7. Jan 24, 2020 at 3:43 AM
    tacoma guy
    Joe
    Phoenix Az.
    Thank you for your reply. Yes for sure I will be investigating were this water is coming from.
  8. Jan 24, 2020 at 4:06 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    As a test, first ensure the windshield replacement did not remove or disturb the rubber edge seal on the cowl that can be seen with removing anything.
    Asa temporary test, take a low adhesion tape, like clear packaging tape, and seal the cowls upper edge to the glass. See if this stops the problem. Very common issue after replacement of the windshield, and has been for many years.
    Jimmyh likes this.
  9. Jan 24, 2020 at 5:17 AM
    tacoma guy
    Joe
    Phoenix Az.
    That is a good idea. I will try that. Thank you!
    Edit I do see that in a couple spots the seal is not contacting the glass. Is about a 6in long area and it is on the passenger side.
    Skyway likes this.
  10. Jan 24, 2020 at 7:24 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Likely that is your leak.
    Skyway likes this.
  11. Jan 24, 2020 at 12:47 PM
    tacoma guy
    Joe
    Phoenix Az.
    It's starting to look like it is. I will definitely look at that. Thank you for your advice!
