2nd gen wheel switch
Discussion in 'Wheels & Tires' started by greentaco15, Dec 19, 2011.
  1. Dec 19, 2011 at 2:37 PM
    greentaco15
    greentaco15 [OP] Well-Known Member
    Adam
    Atlanta, Georgia
    2011 Tacoma Pre-Runner TRD Sport
    Pioneer AVIC-X930BT Headunit Alpine mids and tweeters JL 750 5 channel amp 2 12" kicker subwoofers Smittybilt Bull Bar 2 KC 6" 100 Watt Slimlite Driving Lights
    Hey Guys!
    Ive got a question for all the taco guru's out there. Ive got a 2011 Tacoma TRD Sport PreRunner and I want to fit the XD addict rims on my truck. I would love to be able to do this without rubbing. I am aware that the addict rims are 17x9 which is an increase in width. I want to know if this is possible to do without lifting the truck and what size tire I would be able to run without any rubbing.
    Also, would i have to do both the wheels and tires at the same time or would i be able to do them on separate trips. My current wheels and tires are completely stock on the 2011 Tacoma TRD Sport PreRunner model.
    Thanks
  2. Dec 20, 2011 at 5:54 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If you run a wheel with between 4.5" and 5.5" backspacing, you could run 265/70/17 if the tire is approved for 9" wide rims (depends on the manufacturer and can be found on their website). I have heard of one case of that tire size rubbing with 4.5" BS on a 9" wide wheel, but plenty of other folks run that setup with no problems.
  3. Dec 20, 2011 at 7:29 PM
    greentaco15
    Adam
    Atlanta, Georgia
  4. Dec 20, 2011 at 9:26 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You can run those wheels and tires on stock suspension, they should look pretty awesome too. The only potential issue you may run into is some rubbing on the mud flap because of the negative offset of the wheel, but it shouldn't be bad if it does.
  5. Dec 21, 2011 at 7:42 PM
    greentaco15
    Adam
    Atlanta, Georgia
    Would the chance for rubbing be removed if I take off the mud flaps?
  6. Dec 21, 2011 at 8:42 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    I'm gonna do the same tire on the same width. You'll be fine. It's only approved up to 8.5 wide but it's nothing to worry about.
