2nd gen wiper motor upgrade?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacoman4x4, Oct 13, 2024.
  1. Oct 13, 2024 at 5:32 PM
    09tacoman4x4
    09tacoman4x4 [OP] Member
    09 Tacoma 4.0L 6speed 4x4
    Stock
    Hello friends, so I have an 09 base model taco, and my wiper motor doesn’t have a mist or intermittent speed setting, which is pretty annoying. So I’m wondering if anyone has any recommendations or knows of any windshield wiper motor upgrades that would allow me to have a mist setting or allow more time between strokes
  2. Oct 13, 2024 at 5:40 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  3. Oct 13, 2024 at 5:41 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Oh that's easy, you just replace the stalk switch on the steering column with the delay stalk switch.
    Mist you should have though, that's strange. Can you hear the washer pump when you pull the switch towards you?
  4. Oct 13, 2024 at 5:42 PM
    ABA180
    East Bridgewater MA
    Follow this for the procedure re the switch.
  5. Oct 14, 2024 at 6:37 AM
    bartender138
    bartender138 Active Member
    Ed
    North Shore MA
    2009 2.7L 5M access cab
  6. Oct 14, 2024 at 7:07 AM
    808manokman
    808manokman Active Member
    Vic
    2007 Tacoma 2TR-FE 2.7
    100% stock
    Will this mod work on all base models? 2nd gen?
  7. Oct 14, 2024 at 10:30 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
    It'll work on almost any Toyota product that doesn't have intermittent wipers. I've done it to both my 05 Tacoma and 08 Scion xB. They both use the same parts bin stalk.
  8. Oct 14, 2024 at 12:08 PM
    ABA180
    East Bridgewater MA
    Yessir and not a single bit of wiring needs adding/splicing/etc. Truly is plug and play.
  9. Oct 17, 2024 at 11:36 AM
    mark_tga
    mark_tga Well-Known Member
    2015 Tacoma DCSB
    I can confirm this worked on my 2015 base. Plug and play.
